ducatipaso.org • View topic - Over-revving
It is currently Tue Sep 30, 2025 1:33 am
 Post subject: Over-revving
PostPosted: Fri Jan 05, 2007 12:22 am
PostPosted: Fri Jan 05, 2007 9:21 am
PostPosted: Fri Jan 05, 2007 3:37 pm
AND those metal plates WITHOUT friction material MUST be flat. I mean now, that if they get hot, then they start to be little blue coloured and bent then and then U have to throw them away! There is also one, or two curved plates marked by small dot, so remember to put those dot sides, as they were there, remembering outwards... :confused:
PostPosted: Fri Jan 05, 2007 4:57 pm
The clutch pack is worn out. I wouldn't ride it anymow until it's fixed. Letting the clutch slip overheats the pressure plate and other metal surfaces.
PostPosted: Fri Jan 05, 2007 7:09 pm
Ian, Your clutch plates seems to "slip" and surely then U need new plates, but check carefully all plates, if need all new plates, or only those friction plates. Check also, if any oil is in clutch assy!!! If there is oil, then You have to make bigger job with gaskets between case and clutch and no any need to put new plates to clutch, before U have found/fixes oil leak.... Btw, those STM clutch systems are very good, but more expensive, than normals... :thumbup:
PostPosted: Sat Jan 06, 2007 8:37 pm
which STM clutch model fits in the P750/906 or are you mixing that up with your 907ie ?!
PostPosted: Sun Jan 07, 2007 8:25 pm
PostPosted: Sun Jan 07, 2007 8:56 pm
PostPosted: Mon Jan 08, 2007 4:57 pm
I cant remember just now exact differences between 750 and 907 pressure plates, but i think You can use normal pressure plate with STM 48 teeth basket & plates without any difficulties, like i use also in my 907 just now. My 750 have still original clutch assy, so dont know exact that, cause no need yet to change plates....
I have already one set of red STM 48 basket and plates ready to put to my ST4S, when need to change new plates to her. Ill keep 750 still, like stock.
In this set read:
ALL plates: Clutch plate kit for Original Ducati clutch model 748/916/996 Code: 041 PD 048
Basket: 003MG021 (anodized red)
Remembering, that price was about 490€ last year here basket with all plates...
These both fit to 907 and to my ST4S at least... :evil: But as i told, i dont know exact fit to 750 Paso, but remebering, that it have same basket also....
PostPosted: Mon Jan 08, 2007 8:09 pm
but 907 and St4 don`t have the circlip in the clutch basket as the P750 does. You`ll have to modify the clutch basket.
PostPosted: Tue Jan 09, 2007 7:00 pm
Yes, remembering now, whatkind it was in 750 and propably U are right... :confused: Anyway that my kit is for my ST4S, not for my 750 Paso, what i want to keep stock(clutch). :thumbup:
But maybe only that groove is missing... I check just, that STM basket dont have that groove...
PostPosted: Tue Jan 16, 2007 11:07 am
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Thu Jan 18, 2007 12:01 am
Well, apparently the clutch is completely cactus! And only 77,000klms too! :toofar:
So it's off to the shop I go. I am getting a new clutch and a complete bottom up gasket replacement kit for the engine!!
There goes my superannuation!!!! :sad: I'll let you all know how much this little episode is - the bike has been there a week now..........just as well I love the bastard!!!
See ya in the wind,
Ian
PostPosted: Thu Jan 18, 2007 6:09 am
On my old 906 I had to replace the clutch at only 30.000 km :mad: , even if I used to ride very much in the traffic.
PostPosted: Thu Jan 25, 2007 11:59 pm
Well I finally got my 906 back on the 23rd with a new clutch and full gasket kit - AUD$1497.00 thank you very much. I suppose it's all the labour......
Ian
Red Paso 906
