ducatipaso.org • View topic - Manuals, magazine articles and other downloads
It is currently Sun May 31, 2026 2:20 am
Post new topic Reply to topic  [ 127 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
 Post subject: Manuals, magazine articles and other downloads
PostPosted: Sun Jan 07, 2007 3:08 pm
Hi everyone,
most of the files below can be found also in the document section of the main site.
I`ve uploaded the files on an external hoster, too just in case the site should crash and files get lost as it already happened in the past.
I don`t know if the place I`ve uploaded the files has a traffic limitations, if so pls retry another time.
Also if the pages don`t show in your browser hit the refresh button.
If you own magazine articles, brochures etc and have the possibility to scan them let me know via pm.
Note: if you follow one of the links below and then click on the download button you may get a 'register'/'log-in' pop-up. Ignore that. Just wait a second and you'll get a message from your webbrowser asking if you want to open or download the file.
Brochures and magazine articles:
Magazine articles and reviews
General:
Ducati Paso buyer`s guide
https://app.box.com/s/2fhq2uukm6t3hc14mboele7zupkdgq2e
Ducati Belt-Drive Two-Valve Twins - Restoration and Modification
(Paso/Sport part & appendix - production numbers/ technical specs - only)
Haynes manual SS/Monster (for Paso/Sport relevant parts only)
Overview of clutch discs packs & disc order from SURFLEX
https://app.box.com/s/w2y6okcblz8ve8xtxr45
https://app.box.com/s/0jou7koxsuy3fd8vwhcmratvm8w0m3yo
engine doesn`t start - fault finding chart (doesn`t cover specific 907i.e. issues)
https://app.box.com/s/x8fmn1brzuya97x8z44z
Service bulletin regarding gear selector mechanism - all Ducati models
https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs
Carburation:
Weber manuals
Mikuni manuals
Dellorto manuals
Keihin FCR carb infos/manuals
fuel hose specifications
https://app.box.com/s/ut9pl8qs48zin0rbwf016cal8vtybvb2
Valve timing:
Adjusting valve timing (cam dialling)
about valve timing and camshaft specs
https://app.box.com/s/pst9p706lhf9nvrf8kzpm6kcr5zefayb
timing disc:
http://www.bevelheaven.com/downloads/Un ... ngDisc.bmp
diy TDC finder
Electrics:
charging system (stator & regulator/rectifier) fault finding chart from ELECTREX/ElectroSport
ElectroSport ESR515 and Electrex RR51 installation
Diode testing guide from ElectroSport
Shin Yo regulator installation
https://app.box.com/s/y5n81gem88ul3ymp6a0v
Repairing the ignition switch
Repairing the starter solenoid (shown on a Pantah engine)
Repairing the starter motor (shown on a Pantah engine)
Casting your own front turn signal lenses
Suspension & steering:
Marzocchi M1R fork manual
Marzocchi M1R fork stop rings dimensions
Marzocchi DuoShock service manual
new rear excenters for 17" conversion (17mm axle from a SS can be used, hence no need to machine the wheels to fit larger bearings)
bar risers drawings and CAD files + video
Brakes:
tutorial on how to convert to 4 piston Brembo brake calipers incl. drawings and CAD files
brake adapters and some other info on 17" wheel conversion of P750/906
brake adapters for 17" wheel conversion (calipers with 65mm mounting hole distance)
brake adapters for 300/320mm discs on Marzocchi M1R fork (calipers with 40mm mounting hole distance)
Brembo P4 caliper dimensions
Luggage carrier systems:
mounting instructions for NonFango luggage carrier rack for 906
mounting instructions for Givi luggage carrier rack for 750/907ie
instructions for Givi universal mounting kit (for Givi wingrack carrier systems)
Hepco & Becker luggage rack (german description only)
Ducati Paso 750:
P750 owner`s manual US version
P750 owner`s manual multi language version
P750 owner`s manual - California version (w/ Marelli Digiplex ignition)
P750 workshop manual
P750 parts catalogue
P750 wiring diagram (in colour)
P750 wiring diagram - California version (w/ Marelli Digiplex ignition) (in colour)
P750 wiring modifications
P750 Weber 44DCNF-107 and -110 & jetting
TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires)
Metzeler/Bridgestone
Avon
Ducati Paso 906:
P906 owner`s manual US version
P906 workshop manual
P906 parts catalogue
P906 wiring diagram (in colour)
P906 wiring modifications
Weber mod and jetting for the P906
coolant reservoir modification
Ducati 907i.e.
907i.e. owner`s manual
907i.e. workshop manual (supplement to the 906 wsm)
907i.e. parts catalogue
907i.e. wiring diagram (in colour)
907i.e. wiring modification
swingarm/brake caliper bracket pin - drawing
repairing the fuel pump
adjusting CO trim
adjusting TPS (throttle position sensor)
Unbedenklichkeitsbescheinigung für Reifenumrüstungen (german documents of compliance for alternative tires)
https://app.box.com/s/2bikt9sc0p1knplq1jrpha3stcp2jbhq
left and right swingarm decals (printable pdfs) (these are not for the P750/906 as the necessary chain slack is different!)
https://app.box.com/s/oo896rmygkkgl6gzj08cklpdd5uun0wy
documenti di omologazione (italian homologation documents)
https://app.box.com/s/vxb8chbfpan45ru0q9qqg4b5xr0dygri
Ducati 750S:
750 Sport owner`s manual
750 Sport workshop manual
750 Sport parts catalogue
750S wiring diagram in colour
750S wiring modifications
Ducati 900SS '90:
900 Supersport owner`s manual
900 Supersport workshop manual
900 Supersport parts catalogue
900 Supersport specs
900 Supersport frame, swingarm and fork dimensions
900 Supersport wiring diagram (in colour)
Miscellaneous :
Twist of the wrist 1&2 (pdf books)
Reducing advance timing
Primary gear locking wrench (diy)
Alternator cover puller (diy)
Toolkit contents overview
Spark plug overview for big bore and HC kits
Spark plug heat range crossreference chart
Overview of Marelli Digiplex units
Öhlins shocks service manuals
Öhlins steering damper service manual
label showing setup of California bikes / emission control regulation
Ducati Paso 750, 906 & 907i.e. Info zur Abgasuntersuchung (info for emissions control, relevant for Germany)
desktop background picture Ducati 906 - 1280x1024
Crankcase breather article
2 articles on exhaust systems
article on engine oil
Italo Shop Neuss '93 Katalog
test of Moto Morini 350 Dart (Paso lookalike)
Ducati 851 888 manuals
Remote oil filler (drawing & pictures)
https://app.box.com/s/kohcxdnssrfnyywofb8q4289mqehizfy
Ducati 750 900 Supersport manuals ('91-'97)
Ducati 750 F1 manuals
https://app.box.com/s/wq12jqesd32h5g017za2
Ducati Indiana 350-650 parts catalogue
Ducati ST2 manuals
Cagiva Alazurra 350-650 manuals
Cagiva Elefant manuals
Cagiva Freccia 125 C10R C12R manuals
Reparaturanleitung Monster 600/750 & 900 ab ´93 (german only)
other motorcycle manuals
http://www.carlsalter.com/motorcycle-manuals.asp
http://www.manualedereparatie.info
http://www.pdfmotomanual.com/index.php? ... 8&lang=ENG
Ducati Paso videos:
have fun
 Post subject: Re: Paso magazine articles and other downloads
PostPosted: Sun Jan 07, 2007 5:03 pm
PostPosted: Sun Jan 07, 2007 5:07 pm
PostPosted: Sun Jan 07, 2007 5:10 pm
 Post subject: Thanks Gerhard. You rock!!!!!!!!!!!!!!1
PostPosted: Sun Jan 07, 2007 7:28 pm
PostPosted: Mon Jan 08, 2007 8:43 pm
updated
btw. if anyone is interested in the original magazines (as a bulk, maybe per language) contact me via PM. Guess it won`t be interesting for guys outside Europe though due to shipping cost.
PostPosted: Tue Jan 09, 2007 3:42 am
PostPosted: Tue Jan 09, 2007 10:02 am
PostPosted: Wed Feb 14, 2007 11:39 pm
Rogero
1992 "Red" 907 I.E.
PostPosted: Sat Mar 10, 2007 8:39 am
PostPosted: Tue Mar 13, 2007 9:48 pm
PostPosted: Wed Mar 14, 2007 9:18 pm
thanks to Hårvard (h1a)
added colour 907ie wiring diagram (in higher res as in the post in the 907ie section)
PostPosted: Tue Apr 03, 2007 7:34 pm
PostPosted: Thu Apr 19, 2007 6:50 am
Rogero
1992 "Red" 907 I.E.
PostPosted: Thu Apr 19, 2007 9:35 am
year: 1985
Users browsing this forum: No registered users and 29 guests
