ducatipaso.org • View topic - 800 Heads?
It is currently Mon Jun 22, 2026 10:32 am
 Post subject: 800 Heads?
PostPosted: Sat Jan 06, 2007 6:58 pm
The newer 800ss motor has the same 88mm bore as the 750 (just stroked a bit). Apparently, they vastly improved the flow of those heads. Has anyone dropped a pair on a 750 motor? Does everything line up? Any tricks to get it to work? Does the 800 have an electronic tach, ie, no tack drive on the heads?
Just thinking out loud.
PostPosted: Sat Jan 06, 2007 7:43 pm
Maybe, but for the cost and work involved, it would probably be easier to have the existing heads worked.
PostPosted: Sat Jan 06, 2007 9:21 pm
The old engines, like the Paso ones, have bigger valves than the last engines.
Now the engines use leaner mixture for the pollution reduction.
So, I don't think the newer heads might improve something.
PostPosted: Sat Jan 06, 2007 9:56 pm
 Post subject: Re: 800 Heads?
PostPosted: Mon Jan 08, 2007 2:29 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
