It is currently Sun Mar 08, 2026 4:09 am
| Author |
lammy1
Post subject: Another carb swap project Posted: Mon Dec 04, 2006 4:53 pm |
Joined: Mon Nov 27, 2006 12:00 am Posts: 8 Location: the Netherlands
Hello all,
after reading through the forum I (at last) discovered what could be done about proper carburation.
So many people say bin the Weber and buy some other carbs.
So off I went, buying a Mikuni set from a 750ss.
They were not that expensive so here comes another project for me this winter.
I do have some questions.
On the carb are five tubes what are these for?
I pointed them out with a coloured arrow so we all know which tube we are talking about.
Can anybody give me some hints please?
see pictures below
| Top |
motiztab
Post subject: Posted: Tue Dec 05, 2006 12:33 am |
| Top |
lammy1
Post subject: Posted: Tue Dec 05, 2006 6:41 am |
| Top |
lammy1
Post subject: Posted: Tue Dec 05, 2006 5:08 pm |
Thank you all for your responses.
I now know how to connect my carbs. (I hope)
There is only one question left for me, is it possible to lead the green, red and blue hose to one catchtank?
Or is it advisable to make seperate tanks for the green and red together and one for the blue one?
greetings
| Top |
Post subject: Posted: Tue Dec 05, 2006 5:56 pm |
| paso grand pooh-bah |
good question. Can`t answer that one. Worth a try.
On Monster and Supersport there`re 2 catchtanks
| Top |
750pheonix
Post subject: Posted: Mon Jan 08, 2007 10:31 pm |
| Top |
motiztab
Post subject: Posted: Tue Jan 09, 2007 12:50 pm |
| Top |
Finnpaso
Post subject: Posted: Mon Oct 29, 2007 9:04 pm |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
How important are those "non return valves" in breather lines, cause seems, that Elephant dont have such valves at all? Those hoses were routed only under/behind, (whatever) carbs with 90 degree curves, not to any tank. :confused:
Does Mikunis need fuel pump in 750 Paso? Is it so, that if tank fuel line is lower, than Mikunis, then need pump? (if no pump, then still fuel in tank, when Mikunis dont get anymore fuel with gravity feed)
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
Post subject: Posted: Tue Oct 30, 2007 12:54 am |
Joined: Thu Jun 21, 2007 12:00 am Posts: 1501 Location: Gothenburg, SWEDEN
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
Finnpaso
Post subject: Posted: Thu Nov 15, 2007 6:01 pm |
| Top |
Rodney
Post subject: Re: Another carb swap project Posted: Sun Nov 18, 2007 8:57 am |
Joined: Mon Mar 21, 2005 12:00 am Posts: 101 Location: Sydney Australia
the breather hoses with the return valves need to go to a airbox with limited flow otherwise the needles wont operate properly . ducati part no. for air box is 58510101A . hope this helps.
_________________ Ducati ST2 2002 , Ducati 696 2010 , Ducati Pantah 1983 (in progress )
| Top |
Finnpaso
Post subject: Re: Another carb swap project Posted: Sun Nov 18, 2007 7:26 pm |
So, to WHERE put those breather pipes, if use pod filters? Someone say, that they should route ONLY to such place, where is not anykind air pressure to go in(some tank, or bottle..). I understood from that, that no need to route them to any airbox! (and can then use also pod filters)
| Top |
Post subject: Re: Another carb swap project Posted: Sun Nov 18, 2007 9:42 pm |
here is a pic of Mikuni as they had been removed from the bike
and this is how I had put them on the bike
I guess Rodney is calling these "airboxes", so I think there`s just a misunderstanding here.
| Top |
Post subject: Re: Another carb swap project Posted: Mon Nov 19, 2007 12:48 am |
| Top |
Users browsing this forum: No registered users and 63 guests |
