ducatipaso.org • View topic - mounting exhaust connection
It is currently Fri Mar 06, 2026 3:58 am
 Post subject: mounting exhaust connection
PostPosted: Mon Jan 22, 2007 9:33 pm
year: 1985
Hi guys in this period i plan to mount new 2 in 1 collector,i buy two new gaskets,but i don't understand how i have to recover the ring that hold the exhaust on the cilinder... :confused: :confused: :confused:
give me the light for this upgrade :D
Piero
P.S.
i chose a carby arrow at 45 angle :cool: :cool:
PostPosted: Wed Jan 24, 2007 4:43 pm
year: 1985
help me i don't know how to procede!!!! :oops: :oops:
PostPosted: Wed Jan 24, 2007 5:45 pm
I don't understand what you are asking. Are you wanting to know how to remove the retaining ring from the head or how to remove the ring from the exhaust pipe?
To remove it from the head, you just remove the two nuts that are mounted on the head studs and wiggle it off the studs. In some cases, I've seen the nuts to be over-torqued, which results in the ring being bent and stubborn to come off. Heavy rust could cause problems pulling it off of the studs, also.
To remove the retaining ring from the pipe, you just separate the ring from the flange on the exhaust pipe, and the two half-rings will fall out. If they are badly rusted, they may be sticking, but shouldn't be a problem to get off. Once the half-rings are removed, the ring just slides off the pipe.
Did I answer your question?
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Jan 24, 2007 8:36 pm
year: 1985
demon i want to separate the lock ring from the exhaust pipe,on my manual there can be 4 pieces i think.but on my bike i don't see this....mine paso is of 88 on the new exhaust there isn't lock ring.... :confused: :confused: :confused: :confused: :confused:
PostPosted: Wed Jan 24, 2007 9:21 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
