ducatipaso.org • View topic - Tyre choice ???????
It is currently Thu Mar 05, 2026 5:55 pm
 Post subject: Tyre choice ???????
PostPosted: Fri Feb 23, 2007 10:40 am
Hey PASO’ist.
I am in a situation that I need to change my front tyre. I am lucky to have a dealer near me home has the original Michilin tyre 130 / 60 – 16 in stock to an reasonable price. But I am also considering a new design of tyre, but with know compromise of another tyre dim. 130 / 70 – 16. What is your adveice, sticking to the original or going for an newer tyre design but with a higher profile. If the new design, which make and type would you recommend.
Regards
Klaus
Denmark
PASO 750, 1990.
PostPosted: Fri Feb 23, 2007 1:55 pm
Original type, no doubt!!!
PostPosted: Fri Feb 23, 2007 2:13 pm
Klaus,
I never tried different tires yet, but according to a file I found in the internet in Germany there`s an official tire approval which lists a Michelin 130/70ZR16 Macadam 90x
I don`t know if this helps as this model is not produced any longer but the successor is the 100x, which also exists in that size.
PostPosted: Fri Feb 23, 2007 5:15 pm
The Mac 100's are not listed in those sizes on Michelin UK
http://two-wheels.michelin.com/2w/front ... 03&lang=EN
But they are in atleast some of the common alternative sizes that shouldn't require much modification.
They are quite a long lasting tyre and not exactly at the cutting edge but then neither are the M59 A 59 tyres !
PostPosted: Fri Feb 23, 2007 6:35 pm
I found the 100X in that size on a webpage of an online tire supplier. May have been a typo :(
PostPosted: Mon Feb 26, 2007 10:09 pm
Michelin UK don't always carry the same range as mainland Europe for some reason so They may be avaialble in Germany in that size :mad:
Users browsing this forum: Google [Bot] and 13 guests
