ducatipaso.org • View topic - Crankcase breather plug
It is currently Tue Sep 30, 2025 2:36 pm
 Post subject: Crankcase breather plug
PostPosted: Thu Mar 29, 2007 11:51 pm
Hi Folks,
What would be causing oil to be leaking out from the crankcase breather plug on my 906? I have replaced the plug with a new one and the hose and clamps as well, but it still leaks.
It seems to get worse when I have a cylinder drop out, which is happening very frequently now, but I'm worried that compression is getting through the rings into the crankcase - can anyone help?
Ian
PostPosted: Fri Mar 30, 2007 2:28 pm
Better, that You check compressing pressures and also that flow passing piston rings..... I dont know english word, but in Finland that is "ohivirtaus mittaus" :laugh:
PostPosted: Fri Mar 30, 2007 8:15 pm
PostPosted: Fri Mar 30, 2007 11:08 pm
PostPosted: Sat Mar 31, 2007 1:36 am
Users browsing this forum: No registered users and 54 guests
