ducatipaso.org • View topic - Clutch Piston
It is currently Sun Jun 21, 2026 2:22 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Apr 05, 2007 12:20 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Apr 05, 2007 12:21 pm
PostPosted: Thu Apr 05, 2007 7:52 pm
PostPosted: Thu Apr 05, 2007 8:00 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Apr 05, 2007 9:44 pm
PostPosted: Fri Apr 06, 2007 9:16 am
btw. the pin dimenstions are:
______________
I.............................I
..........I.......I
..........I.......I
..........\___/
diameter top: 16mm (0,63 inch)
total height: 9,10mm (0,358 inch)
height of flat top: 2,20mm (0,086 inch)
diameter of the lower section: 7,97mm (0,314 inch)
An M8 bolt has a 13mm head (e=14,38mm, see link below), so even if it not 100% matching the easiest way would be to shorten an M8 bolt (I`d suggest DIN920 as these have a thread only at the end) and machine down the head.
Interesting in this case would be how long the non threaded section is, but I guess at the end it doesn`t make any difference also if you use a finethreaded bolt with thread up to the head (DIN961).
http://www.online-schrauben.de/cgi-bin/ ... 931-2-8-35
(on the right, click "M8x1" and then on "technische Info")
I don`t think that the 3mm less top diameter have any negative effect. But there`re also different types of bigger headed M8 bolts like i.e. this type:
http://www.online-schrauben.de/cgi-bin/ ... 921-2-6-16
(on the bottom left "DIN6921")
there`re for sure even better matches that could be used.
.... this just as an idea
PS: my original piston is not magnetic and according to the colour it`s out of brass, this just as a sidenote
PostPosted: Fri Apr 06, 2007 11:03 pm
PostPosted: Sat Apr 07, 2007 10:23 am
PostPosted: Sat Apr 07, 2007 7:29 pm
PostPosted: Sun Apr 08, 2007 5:33 pm
PostPosted: Sun Apr 08, 2007 6:18 pm
PostPosted: Sun Apr 08, 2007 6:47 pm
 Post subject: Piston for sale
PostPosted: Mon Apr 09, 2007 5:44 am
PostPosted: Mon Apr 09, 2007 8:05 am
PostPosted: Mon Apr 09, 2007 9:52 am
