ducatipaso.org • View topic - MARZOCCHI M1R
It is currently Thu Oct 02, 2025 7:19 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Post subject: MARZOCCHI M1R
PostPosted: Fri Apr 06, 2007 2:19 am
1992 907ie #1473 Nero SOLD
PostPosted: Fri Apr 06, 2007 12:46 pm
I just replaced the seals and dust boots on my '87 Paso 750 Marzocchi M1R forks. They are still available through Ducati. I got the dust boots from http://www.proitalia.com and was fortunate enough to find a local shop that had some OEM Marzocchi seals that were also used on an 80's KTM dirtbike. Here are the measurements that I got from the original components on my Paso....
Seal (marked 41 - 55 - 10 - 10)
ID = 41mm
OD = 55mm
Thickness - 10mm
Dust boot/scraper (no markings)
ID = 41mm
OD = 60mm
Total height - 13~13.5mm
OD of lip for slider - 55mm
Height of lip for slider - 5mm
Thickness of section that rests on top of slider - 3mm
I hope this helps.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Sat Apr 07, 2007 12:14 am
PostPosted: Sat Apr 07, 2007 8:14 am
Last edited by persempre907 on Mon Apr 09, 2007 10:06 am, edited 2 times in total.
PostPosted: Sat Apr 07, 2007 1:14 pm
PostPosted: Sat Apr 07, 2007 4:13 pm
PostPosted: Sat Apr 07, 2007 7:49 pm
PostPosted: Sat Apr 07, 2007 8:35 pm
PostPosted: Sat Apr 07, 2007 9:03 pm
PostPosted: Sun Apr 08, 2007 9:16 am
 Post subject: availability from ducati?
PostPosted: Mon Apr 09, 2007 3:27 pm
I was under the impression that these seals were unavailable from ducati any more???
i have no local,indeed no in state ducati dealers at all and will try to call BCM as they are always recommended on the ducati list.
however if that falls through i will go back to the marzocchi guys and hopefully come up with a set of seals/scrapers.
anybody know for sure what the status is?
doug
 Post subject: Re: availability from ducati?
PostPosted: Mon Apr 09, 2007 4:55 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Apr 09, 2007 7:09 pm
PostPosted: Mon Apr 09, 2007 7:51 pm
PostPosted: Mon Apr 09, 2007 10:47 pm
