ducatipaso.org • View topic - Marzocchi supermono rear shock questions
It is currently Mon Mar 09, 2026 8:55 am
 Post subject: Marzocchi supermono rear shock questions
PostPosted: Sun Apr 15, 2007 7:46 am
My rear shock (Marzocchi supermono) seems not to respond to any regulation, so I'm afraid I have to rebuild it. I bought a used unit from eBay, but how can I tell if it is in good conditions before mounting it into the frame?
A racing mechanic recommend to rebuild it in any case, because with aging the oil loose its properties and should be replaced. It sound reasonable, but it's not so easy because the unit is very old. I found a specialist that could manually rebuild any worn components, but he asked me 700€ to do it :sad:
Since I have two units, I can afford to break one of them.... so do you think it's possile to try to change oil of one of them by myself? Is it a difficult or too specialized task?
I know that for Aprilia Pegaso or AfricaTwin it can be done:
Or... does anyone knows a good (and cheap) specialist in northern Italy? :roll:
Many thanks!
LC
PostPosted: Tue Apr 17, 2007 5:29 pm
PostPosted: Tue Apr 17, 2007 7:27 pm
PostPosted: Tue Apr 17, 2007 11:09 pm
PostPosted: Wed Apr 18, 2007 8:18 am
PostPosted: Fri Apr 20, 2007 6:32 pm
PostPosted: Fri Apr 20, 2007 6:56 pm
PostPosted: Fri Apr 20, 2007 8:10 pm
