ducatipaso.org • View topic - Wiring upgrade Choke/ idle issue
It is currently Sun Jun 21, 2026 12:00 pm
 Post subject: Wiring upgrade Choke/ idle issue
PostPosted: Wed May 09, 2007 5:59 am
PostPosted: Wed May 09, 2007 12:17 pm
PostPosted: Wed May 09, 2007 3:54 pm
 Post subject: hmmm
PostPosted: Fri May 11, 2007 3:33 am
PostPosted: Fri May 11, 2007 4:26 pm
PostPosted: Fri May 11, 2007 8:21 pm
 Post subject: ordered
PostPosted: Fri May 11, 2007 11:31 pm
PostPosted: Sat May 12, 2007 8:45 am
PostPosted: Sat May 12, 2007 3:11 pm
PostPosted: Sun May 13, 2007 10:56 pm
I am not sure what caused the rpm drops. I was getting a reading of 11.8 to each coil and there was equal pressure coming out of the exhausts. I will try the wiring mod again once the regulator/ wiring situation is tamed.
PostPosted: Mon May 14, 2007 7:25 pm
There is a crossover in the exhaust, so checking the end of the muffler to see if one cylinder is running doesn't work.
PostPosted: Mon May 14, 2007 7:51 pm
Yes, better to check the temperature of the header pipes (before the X).
