ducatipaso.org • View topic - 907 hot starting
It is currently Thu Jul 16, 2026 7:02 am
 Post subject: 907 hot starting
PostPosted: Sun Feb 27, 2005 11:59 am
My 1990 907IE starts from cold ok, with aabout 1/3 choke but from warm or hot it fires up and cuts out refusing to start again until cold. Has any one expeienced this problem or can point me in the wright direction?
PostPosted: Mon Mar 07, 2005 10:09 am
Hi "nut"!
Have You checked Your valve clearances allready??? Thinking, what happen, when exhaust clearances are too tight.....Easy to check! Maybe start ok, when cold, but when engine warms, then Not anymore, cause no pressure in sylinder........
Finnpaso
PostPosted: Fri Mar 25, 2005 7:07 pm
PostPosted: Tue Mar 29, 2005 10:07 am
Hi!
I hope You remember also drive and accelerate very hardly, BEFORE You check You valve clearances! No need to check valve cl. if Your valves are very dirty! Many forget that very important point before valve check..... Engine must be as "clear" as possible before job ;-) Here guys, who check other Ducks valves, do first very hard test drive to clear valve area from all shit...
...still thinking, that there can be some problems to figure out....
Finnpaso
Antti
