ducatipaso.org • View topic - Bilding a Streetfighter
It is currently Sun Jun 21, 2026 10:42 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Jun 02, 2007 8:08 pm
I think, You are doing very, very rare job now.... :thumbup:
PostPosted: Sun Jun 03, 2007 10:21 am
It is more like an Paso streetfighter.
PostPosted: Sun Jun 03, 2007 10:22 am
PostPosted: Mon Jun 04, 2007 6:44 pm
After body, You have to make/put POWERFUL engine and right sprockets! Normal Z=15 to front and something Z=46-48 to rear. I promise, then it "wheelies" very easily! :laugh:
PostPosted: Mon Jun 04, 2007 10:10 pm
year: 1985
Karel do you want to cut tthe lower paint of the frame cause i don't see that in your photo...
:confused: :confused:
is this sure to do???
howewer very good job :thumbup:
but i don't like too much front fairing too much jappy for me :D :D :D
PostPosted: Sun Aug 19, 2007 12:22 pm
Dear Paso frends,
Afther a long time of thinking I have bought an other Frame.
So the Paso project is no longer.
I have now and SS and that is what more waht I like.
This will be my new Streetfighter project, it will be an 944SL.
The frame is allready red, the wheels red and the other parts black.
Greetings,
Karel.
PostPosted: Tue Oct 23, 2007 3:38 pm
Did you have to cut the Paso frame because of the width of the engine? Is the lower frame rail (the removable one) in the way of the water pump and water lines?
I'm just curious, because I've run across a 916 engine with the complete wiring harness, throttle-bodies, and ECU and am toying with the thought of throwing it into the rolling-chassis (Paso 750) that I have. If not, it can always be a future "upgrade" for my ST2 or 748. I have been thinking about a pair of large dirtbike radiators to go into the side fairings like the existing oil coolers and maybe adding an oil-cooler to the lower section of the horizontal head, just like newer Ducatis. I was also thinking that maybe an external fuel pump should be good enough for the fuel feed without having to modify the original tank.......I wonder if there is enough room under the tank for a Monster or ST airbox lower.
With my current Paso Project almost done, I'm itching to start on another project. :laugh:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
