It is currently Tue Sep 30, 2025 8:37 pm
[ 4 posts ] |
Author |
enzo906
Post subject: 906 repairs / adjustments Posted: Tue Jun 12, 2007 3:23 am |
Top |
persempre907
Post subject: Posted: Sun Jun 17, 2007 6:23 am |
paso grand pooh-bah |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Hi Enzo,
the water leak from the pump is a frequent issue.
It's quite easy fix it: you need only replace the ring on the shaft.
The water pump is the same of the later Ducati, so you wouldn't have any problem to find it.
Unfortunately, I haven't any experience with the Dellorto carbs. I cant' help you.
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
Top |
marshman
Post subject: Posted: Sat Jun 23, 2007 7:59 am |
Howzit
Welcome to 906 land,once your on top of it dude" she'll be right !bro".The faults are plentiful but are all easily overcome.Most parts [crank ]are shared with 907,851,916,ST2 etc [eg all water cooled models] Couple questions : How you testing for manifold air leaks ??have you set vacuum for ignition unit[assuming you got OEM Magnetti-marreli digiplex unit]
Ducs are very easy to work on if you have a good mechanical mind .Common size hex heads all over .but beware the Italians like 15mm as a bolthead size.
Cheers Andrew
Top |
jomo
Post subject: Posted: Wed Aug 01, 2007 11:33 pm |
Joined: Sun Jul 18, 2004 12:00 am Posts: 127 Location: Australia
_________________ Brake late & brake hard, jomo
Paso 906 Blue Paso 906 Silver Bultaco Metralla GT370 Custom Bultaco Metralla GT250 Bultaco Frontera 250 Mk.9 Suzuki RMX250
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 5 guests |
