ducatipaso.org • View topic - Paso muffler cross reference
It is currently Sun Jun 21, 2026 3:34 pm
 Post subject: Paso muffler cross reference
PostPosted: Sat Jun 09, 2007 5:26 pm
PostPosted: Sun Jun 10, 2007 6:30 am
it's an hard work to fit such mufflers on paso pipes.. You might think I'm fooling you, but I can say it's not so easier thanbuilding your own mufflers starting from zero!
It's very cheaper buy iron cans in an "acme" store and design the best muffler you can image! Afterwards, you can match the same on stainless steel, lighter and nice looking!
Here're the links to mine:
It's still not so nice to see, but...
PostPosted: Sun Jun 10, 2007 6:45 am
PostPosted: Sun Jun 10, 2007 4:28 pm
year: 1985
PostPosted: Sun Jun 10, 2007 11:53 pm
Actually the 2 in1 was jet intalled on the bike, but the 50 mm to 40 muffler wasn't able to make the engine run correctly, so I designed and built a new muffler following my ideas about exaust flowing, and it runs very better than any other I tested on my dukess...
Anyway, following the same idea and choosing the right diameter for the internal cans, I think that you can build your own 40 mm couple of mufflers :thumbup:
You only need to leave a regular "front surface" (what's the correct term for this???) of the 2 in 2 pipe that should be
[(40/2)^2] x 3.14= 1256 sqr millimeters
so the secondary can should be about 60mm diameter
and the external cover about 75 mm
for a total lenght about 400 mm;
then try to cut a small part to reach a better flowing
Try to believe!
PostPosted: Mon Jun 11, 2007 5:46 am
I have 2 stock sets of mufflers. My plan for now is to cut open the bottoms/backs of a stock set , Say about 2 1/2 inches (6-7 cm) by about 14 inches (35cm) remove some of the internal baffling, then weld it back shut. Smoothy finish then repaint. The parts I cut open will be on the underside and back, hidden from view but nicely finished.
What do you think?????
PostPosted: Mon Jun 11, 2007 9:02 am
year: 1985
My inlet are 42mm from cylinder to one 46.....
outlet is 60 if i remember correctly???
lamps
Piero
PostPosted: Mon Jun 11, 2007 5:17 pm
PostPosted: Mon Jun 11, 2007 6:30 pm
year: 1985
PostPosted: Tue Jun 12, 2007 8:03 am
PostPosted: Tue Jun 12, 2007 10:39 am
year: 1985
here are the photo :D
[img][img]http://i172.photobucket.com/albums/w10/madpiero/IMG_0038_1.jpg[/img]
[/img]
