ducatipaso.org • View topic - Weber diassembly
It is currently Fri Jun 19, 2026 10:03 pm
 Post subject: Weber diassembly
PostPosted: Mon Jun 18, 2007 1:29 pm
Ok I'm looking at the Weber, removed the three screws on top , two in front in in the rear, which I think should remove the top of the carburator so I can get into the float bowl, but it is solid. Do I have to remove from bike to take it apart?
 Post subject: Weber Disassembly
PostPosted: Mon Jun 18, 2007 4:50 pm
There are four screws on the top of the carburetor, one at the back center, one at the left front, and two at the right front, one of them in front of the fuel inlet, one of them behind the fuel inlet. You may have to lightly tap the cover to loosen it once the screws are removed, depending on how long it has been since it was previously dis-assembled.
There is a download on this web site of an exploded view of the 44 DCNF carb, which will help you to see where all the parts are.
Good Luck!
PostPosted: Mon Jun 18, 2007 5:49 pm
Ok I must have missed on of the right fronts.
Small world. I'm working in Windsor above Webster bank today.
 Post subject: her it is
PostPosted: Mon Jun 18, 2007 5:59 pm
http://s211.photobucket.com/albums/bb17 ... G_0088.jpg
Looks great, will not run. Was off the road for three years. Was well taken care of.
PostPosted: Mon Jun 18, 2007 7:42 pm
PostPosted: Mon Jun 18, 2007 7:56 pm
PostPosted: Tue Jun 19, 2007 12:27 am
PostPosted: Tue Jun 19, 2007 1:43 am
PostPosted: Tue Jun 19, 2007 2:26 am
