It is currently Fri Jun 19, 2026 11:40 am
[ 5 posts ] |
| Author |
rjc
Post subject: Marzocchi M1R front forks . . . Posted: Tue Jun 19, 2007 5:13 pm |
I started SLOWLY parting out my ’87 Paso 750 just before winter last year.
Anyway, I now want to sell the front end as one complete unit; complete forks, upper linking plate, steering crown, etc. My question is in removing this from the frame.
I have the steering head removed. I know that you should not re-use the steering bearings once removed from the column. If I unscrew the adjustment ring nut and remove it, when I extract the fork pin from the column, will the bearings come falling out? Can I safely remove the fork pin, remove the entire front end from the frame, put the pin back in, and then put the adjustment ring nut and head back on?
The front end is in great condition and I’d like to keep it that way. Obviously, I haven’t done this before to have seen it, so any additional information is greatly appreciated.
Thank you in advance.
| Top |
persempre907
Post subject: Posted: Tue Jun 19, 2007 5:55 pm |
| paso grand pooh-bah |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Don't part out your nice bike!
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
rjc
Post subject: Thanks, but . . . Posted: Tue Jun 19, 2007 6:26 pm |
Too late. Engine, frame, wheels, about all that's left. A few other misc parts.
All mirrors, plastic, electric, lights, tires, more gone.
Just think of all the Paso's that live on . . . you're welcome very much!!!
:thumbup:
| Top |
Desmo_Demon
Post subject: Posted: Wed Jun 20, 2007 7:31 pm |
Joined: Fri Jul 21, 2006 12:00 am Posts: 869 Location: Easley, SC
Once you have the upper triple clamp removed, you remove the round stem nut (ccw - loosen the pinch bolt first).....
...once this nut is removed, the nut can come off and then you can just roll the fork assembly out from the bottom of the steering head.
The upper, taper roller bearing will stay with the race inside the tube. The spacer (distance piece) will also stay on top of the bearing and probably be held in place by the seal....This is with a green, aftermarket seal (the original is similar to a washer with the inner ID lined with rubber)....
Here is a top view with the spacer removed and the new (aftermarket) seal in place....
The bottom bearing is press fit onto the steering stem, which is in return press fit into the bottom triple clamp. The race for the bottom bearing will stay in the steering tube, as this is press fit into it. Here is a picture of the bottom race still in the frame (the old seal is partially removed in this picture)....
I can't think of anything that you may have issues with in removing the front end. It is fairly simple to do. If you have any other issues, feel free to contact me, as I've removed everything but the engine from my '87 Paso in the last 11 months.......You have the two spacers that go between the engine and the swingarm available? It is the piece on the far right in this picture....
_________________ 2002 Ducati 748 monoposto 1998 Ducati ST2 1996 Suzuki GSXR-1100 1994 Bimota DB2 1988 MegaPaso 916 project 1987 Ducati Paso 750 1985 Harley FXEF 2001 Ducati M900ie (wife's) 2000 Yamaha YZF-R1 (wife's) 1998 Ducati ST2 (wife's) 1994 Suzuki GSX-750R (wife's)
| Top |
rjc
Post subject: Thank You . . . ! ! ! Posted: Fri Jun 22, 2007 2:41 pm |
Thank you VERY much! That was easy. Everything happened precisely as described, no issues.
Frame Top, after removal:
Frame Bottom, after removal:
Front after removal:
Again, thank you for your help and btw - I have yet to remove the engine from the frame, so yes, I have the spacers.
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 11 guests |
