ducatipaso.org • View topic - Hi! Newbie w questions
It is currently Sat Apr 25, 2026 5:44 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Jun 23, 2007 8:43 pm
PostPosted: Sun Jun 24, 2007 4:29 am
PostPosted: Sun Jun 24, 2007 7:36 pm
I am quite sure, its "newer Conti", but painted to black later... :evil:
PostPosted: Mon Jun 25, 2007 12:32 am
PostPosted: Mon Jun 25, 2007 7:11 pm
 Post subject: Re: Hi! Newbie w questions
PostPosted: Mon Jun 25, 2007 9:41 pm
'91 907ie (Red)
'93 907ie (Red)
'93 907ie, w/ worked engine (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
'82 Kawasaki KZ1100 Spectre (Wine/Black)
PostPosted: Tue Jun 26, 2007 4:30 am
Frankie: rev limiter is INSIDE EPROM, NOT "inside other part of ECU", so If You have some "tuned" EPROM, its normal, that limiter is out of working, OR its set to higher RPMs. Original 907 Eprom have limiter in 9000 rpms. :evil:
Contis are quite open/free flow exhausts, but mostly best ever made pipes, if thinking sound. Pitty, that chrome is not so good quality in thise chromed ones. :sad:
Btw, Ducatis enginbes are normally "designed" to use 2-2 exhaust system, thats why 2-1 is not so good and often cause adjusting problems. I use allways 2-2 systems. :thumbup:
PostPosted: Tue Jun 26, 2007 9:38 am
PostPosted: Tue Jun 26, 2007 12:15 pm
PostPosted: Wed Jun 27, 2007 8:35 pm
My ECU name:
Weber 1IAW Italy 043/04 Marelli electronica WU43.07/20A.28
EU on lid
Chip:
Ducati 907ie -23- 04
Do I have a P7 w a OEM ducati chip?
Anyone has a pic of their open airbox lid? Do you just open it as much as possible or what?
Most popular gearing? Had 15/39, really high!
PostPosted: Sat Jun 30, 2007 7:00 pm
U have P7 and original Eprom. :thumbup:
I use 15 / 46 gearing.... I dont need top speed, only hard acceleration against those jap bikes in twisty roads and that function very well.... :evil:
PostPosted: Sun Jul 01, 2007 1:04 am
Wow, 15/46 sounds extreme! What RPM`s in 6th at 120km/h?
Tried 14/39 (shaved off a M900 front sprocket!), quite OK, 4400 RPM 6th gear at 120km/h. Think it will be15/41 next spring.
PostPosted: Sun Jul 01, 2007 6:58 am
PostPosted: Sun Jul 01, 2007 7:49 pm
PostPosted: Sun Jul 01, 2007 7:51 pm
