ducatipaso.org • View topic - twin mikunis 88 paso 750
It is currently Sun Jun 21, 2026 12:04 pm
 Post subject: twin mikunis 88 paso 750
PostPosted: Wed Jul 18, 2007 10:11 pm
Hi I have installed twin mikunis and the bike idles and runs fine unti 4k rpm, where it begins to break up badly. the installation was different than the posting i noticed with the fabricated airbox. The only way i could mount them(carbs are not connected) is side by side opposing each other at a 30 degree angle, this was with short manifolds i was able to fit the k and n cone type filters. the shop i bought the carbs form claimthey were only used to bench test ducati race motors and they may be overjetted for my bike as it is stock except for yoshi slip ons, any ideas? the carbs look brand new in and out, not sure what jets are in them, hoped not to have to take them apart!
thank you in advance.
Eric,.
PostPosted: Sat Jul 21, 2007 10:38 am
mikuni setting is quite an hard job.
you have to work with main jets additional jets, springs and so on.
You might be happening to face a too lean mixture because of a large amount of wrong settings. If you don't know how to work on it, you'll need a good mechanic help :ugh:
PostPosted: Tue Jul 24, 2007 9:36 pm
Popping or break up sounds like a lean condition to me. You may have to go into the carbs and install bigger main jets. Like said in the previous post, you want to bring it to qualified mechanic. They should be able to sort it out rather quickly.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Wed Jul 25, 2007 2:42 pm
PostPosted: Wed Jul 25, 2007 3:11 pm
PostPosted: Wed Jul 25, 2007 4:15 pm
PostPosted: Wed Jul 25, 2007 4:33 pm
PostPosted: Wed Jul 25, 2007 6:37 pm
 Post subject: manometer
PostPosted: Wed Jul 25, 2007 6:39 pm
PostPosted: Thu Jul 26, 2007 4:23 pm
Have a look to my "hand made-supercheap-easy to use"
:thumbup:
 Post subject: In Tampa too...
PostPosted: Wed Sep 05, 2007 2:05 am
I own a 1988 Paso 750... My number is 800-516-6402 ... Have you checked out Syds cycles in Pinellas park ? Oldman Syd has the best restored Ducatis in town...
 Post subject: Re: manometer
PostPosted: Wed Sep 05, 2007 10:45 am
PostPosted: Tue Sep 25, 2007 12:40 pm
PostPosted: Fri Oct 05, 2007 11:42 am
What mainjets & needle setting, Rodney?
PostPosted: Sun Oct 07, 2007 12:45 pm
hi
the needle height from memory was slot 4.
the needle jet ducati part no. 13240041B
the idle jet ducati part no. 13240031B
these are to suit mukuni's for a 96 750 ss as my carbs are off a 96 900 ss.
they work well for me no flat spots and quick throttle action.
hope this helps
Rod
