ducatipaso.org • View topic - 750 paso clutch
It is currently Mon Sep 29, 2025 1:40 pm
 Post subject: 750 paso clutch
PostPosted: Tue Jul 24, 2007 4:12 pm
I was out on my 750 paso the other day and i had only done about 10 mile or so and the clutch started to slip so i returned home and took off the fairing panel then the clutch cover to find that there was a clutch bolt and spring missing there were only 5 instead of 6 bolts and springs so i removed the 5 bolts and springs and found that a previous owner had snapped off a spring post and had tried to have it welded back on obviously without success hence the missing spring and bolt. Is the pressure plate still available from the dealers or will i have to try and find one elsewhere, do any of the other Ducati models share the same clutch?? here's a pic or 2 off the clutch.
Dave
PostPosted: Tue Jul 24, 2007 5:17 pm
That is the inner pressure plate (sometimes called an inner hub) - part #066516630 - and that post breakage is not too uncommon. I broke one on my Harley and had it welded up, only to decide against using it and bought a new one. If you have it welded, it needs to be perfect, as if it isn't, it will take the rotational forces when you let the clutch out and it will break, again.
Chances are, that probably isn't your slipping problem. Not that I would do it, but some people have been known to remove a couple of springs to make their clutch pull a little easier.
I don't know if they are still available or not or even if they are interchangeable with any other Ducati. Surfing eBay may result in finding one. If someone lists Pantah engine parts, I'd send them a message asking if they have that part.
Edit - You'll have to send them a message, but an eBay search shows these guys may have that part available....
http://search.stores.ebay.com/Los-Angel ... 74QQsofpZ0
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Jul 25, 2007 8:04 am
So i could carry on using the inner pressure plate as it is and just renew the clutch plates??? i know the clutch slip was caused by worn out plates but the missing spring post was unexpected when i checked the clutch out. i am just waiting on a reply from the dealer about availabilty of the inner p/plate hopefully it's still obtainable.
thanks
Dave
PostPosted: Wed Jul 25, 2007 11:07 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Jul 25, 2007 6:23 pm
PostPosted: Wed Jul 25, 2007 6:37 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Jul 25, 2007 6:55 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Jul 25, 2007 9:10 pm
Users browsing this forum: No registered users and 52 guests
