ducatipaso.org • View topic - new to me 907, weak charging.
It is currently Mon Apr 27, 2026 11:53 am
 Post subject: new to me 907, weak charging.
PostPosted: Fri Aug 10, 2007 12:17 pm
PostPosted: Fri Aug 10, 2007 8:41 pm
PostPosted: Fri Aug 10, 2007 9:53 pm
PostPosted: Fri Aug 10, 2007 11:54 pm
PostPosted: Sat Aug 11, 2007 9:31 pm
Looks just original 92 modell, in good shape, so DONT drop it down and those ch. problems are very normal to ALL Ducati modells from 90s and they only need to fix and find problem places, cause if You loose regulator, its then very easy to loose also much more expensive rotor from inside left cover. THATS why, better find bad connector/connections, before its too late... :evil: LUCK to You and to Your nice 907! :thumbup:
PostPosted: Sun Aug 12, 2007 1:31 am
Find and clean every ground in the system.
The clean everyting else. The good news is that it's charging!
PostPosted: Thu Aug 16, 2007 6:24 pm
It looks great but needs the AGIP decals on the side fairing to finish the bike off...
Rogero
1992 "Red" 907 I.E.
