ducatipaso.org • View topic - NEED PARTS FOR MY 906 BAD!!! PLEASE HELP!
It is currently Wed Apr 15, 2026 12:52 am
 Post subject: NEED PARTS FOR MY 906 BAD!!! PLEASE HELP!
PostPosted: Fri Aug 24, 2007 3:14 am
Hello to my new friends and Duc lovers. Got a great Paso with the usual details that need completing. I need some parts for my 1990 906 to make it as perfect as possible.
Here is the list:
1. New taillight assembly including lens (it has built in turn signals)
2. Left/Right front turn signal lenses (I'll take the whole assembly)
3. Round mirror (if you have suggestions for replacement, rather than original, I am open.
4. Trim piece that goes under the instrument cluster
5. Front upper fairing (headlight area, aka windscreen)
6. A working clock.
7. Risers would be nice (aftermarket item)
Thank you all in advance for any help and suggestions.
PostPosted: Fri Aug 24, 2007 12:26 pm
PostPosted: Sun Aug 26, 2007 5:40 pm
PostPosted: Mon Aug 27, 2007 10:53 am
PostPosted: Tue Aug 28, 2007 5:00 am
Thanks for some of the advice. Here is an updated list:
1. New taillight assembly including lens (found and purchased-dealer)
2. Left/Right front turn signal lenses (found and purchased-Ebay)
3. Round mirror (if you have suggestions for replacement, rather than original, I am open. (Joan's Fabric .99 cents 4" perfect fit, dealer wanted $40.00 usd)
4. Trim piece that goes under the instrument cluster (may use diamond plate and fabricate piece)
5. Front upper fairing (home repaired job, looks tolerable)
6. A working clock (still hoping)
7. Risers would be nice (going to a machine shop with suggested plans, thank you kindly for that info)
8. New Item: Cooling expension/resorvois tank.
Thanks guys/gals for reading my post and offering suggestions.
