ducatipaso.org • View topic - 907 Plug & switch
It is currently Sat Feb 28, 2026 12:52 pm
 Post subject: 907 Plug & switch
PostPosted: Thu Aug 30, 2007 9:19 pm
Looking for;
1- The plastic terminal/plug that connects the sidestand warning light, fuel gauge, neutral light wires to the bottom of instrument board.
I know, another probable "hopeless" search but trying anyway.
2- Rear brake switch as the current one I have to apply excesive pressure to activate.
Otherwise enjoying this fine machine....Thanks!! :thumbup:
PostPosted: Fri Aug 31, 2007 2:28 am
One part was on Ebay but now it is gone. The rear brake switch you should be able to get from the dealer. I believe it is a Brembo part. On the rear switch make sure your brake fluid pressure/level is correct first prior to assuming it is the switch. Just some troubleshooting thoughts. I'll keep my eyes open.
PostPosted: Fri Aug 31, 2007 5:45 am
Thank Wine...that might just be it as the shop installed new braided brake lines recently, maybe it'll be a "need" for a bit of brake fluid.
PostPosted: Fri Aug 31, 2007 1:40 pm
Got my switch from a Ducdealer.
PostPosted: Fri Aug 31, 2007 1:44 pm
Thanks for the info.
