ducatipaso.org • View topic - Lighter flywheel
It is currently Thu Oct 02, 2025 12:22 am
 Post subject: Lighter flywheel
PostPosted: Thu Oct 04, 2007 9:49 am
year: 1985
He guys in thes days i'm thinking about installing a lighter flywheel,what are your suggestion???have you tried it and where i can find one??
Maqny thanks
Piero
PostPosted: Thu Oct 04, 2007 4:38 pm
a lighter flywheel requires a perfect carb sinc at idle and low rpm, as a lower inertial sistem can't help you in slow riding (traffic and similar)
As you surely did read in desmodromico.com, m600 flywheel should be suitable on 750 engines
PostPosted: Fri Oct 05, 2007 12:17 am
Did that on my M900. Removed 1,5kg.
Very enjoyable! No big problems w idle etc, just a more fun fast revving machine!
If engine is tuned good, you will have no problems widle, slow traffic etc.
Go for it!
PostPosted: Fri Oct 05, 2007 10:34 am
I quote a very interesting (and long) article from :
______________________________________________
Light weight flywheels - What do you think?
submitted by Larry Kelly, Alex Ortner
The following is Larry Kelly's excellent response to the question below. I think it's the best explanation of the pros and cons of this often questioned "upgrade". Following Larry's opinion is Alex Ortner's opposite opinion, also worth posting because as with many modifications you can do to your Ducati, there's more than one opinion:
On May 3, 2004, at 9:15 AM, DUEVALVDUC@aol.com wrote:
> I understood you to say that your were opting > for the slipper clutch over a lightened flywheel. Is this an either/or > proposition? I understand the benefits of the slipper, but isn't there > still something > to be gained by lightening up the rotating mass of the engine?
Larry's reply:
A lightened flywheel is one modification to a street bike that will have more negative than positive effects. I left mine stock. Here’s why.
Why You Have a Flywheel
An engine makes the least torque at idle and low rpm, especially when cold (when there are more misfires.) So when you release your clutch a little too fast, the engine torque is too small to overcome the bike's inertia, and it stalls. If you have a flywheel, the stored momentum augments the engine's torque allowing you to use a lower rpm starting-off. Without a flywheel you'd need a higher idle speed, or constantly need to start-off at a higher rpm in order to raise the engine torque output enough to avoid stalling the engine.
As you ride at lower rpm in traffic, you are constantly changing between acceleration and deceleration. Engine torque levels are still fairly low at these speeds, so slack in the drive train needs to be smoothed-out with a flywheel. Otherwise, on-off throttle transitions have a jerky effect, giving a less comfortable ride and causing you to use smaller throttle inputs (which is not always easy to do.)
At higher speeds a flywheel slows the rate at which an engine rpm changes, so cracking the throttle open or closed results in a smoother transition in torque being applied to the drive train and tires. Again, without a flywheel more careful throttle transitions are needed. The key to faster track times is reduced wheel spin so a light flywheel works against you by making it more difficult to modulate wheel spin, even though it helps lap times by producing more acceleration in the straights.
So in effect, a flywheel slows an engine's ability to change rpm producing drive train smoothness and drivability. It also reduces the engine's ability to match it's rpm with the drive train's rpm making it more difficult to downshift without producing wheel-hop.
And, when you miss a shift you’ll be glad you have one.
Lightweight Flywheel - Pros and Cons
The weight of the stock flywheel is selected by Ducati test riders to provide an overall balance between performance and smooth drive train behavior.
When you remove weight from the flywheel (and to a lesser degree, from the clutch) the effect on the engine’s ability to more quickly spin-up is indistinguishable from increasing your engine’s torque (and consequently horsepower) output.
But only in neutral. In any other gear, there’s little benefit at all.
Obviously, your bike’s ability to accelerate faster through the gears is enhanced by reducing the overall weight of the bike as well as the inertia of rotating components. The crankshaft, pistons and connecting rods, transmission gears, drive chain and sprockets, wheels and tires, clutch and flywheel are all candidates.
However, the overall weight of the bike and rider completely overwhelms any reduction of rotational inertia produced by a lighter flywheel. A two pound lighter flywheel on a 600 pound bike-plus-rider will accelerate only 0.3% faster. F=ma.
Of course every 0.3% helps a racebike. When you reduce weight you’ll get faster acceleration, and faster lap times - IF - you can modulate your wheel spin driving out of corners. Factory racebikes make so much power, for example, that transmitting the power to the road effectively becomes the limiting factor - so heavier flywheels actually become a benefit. Fear the high-side.
The ability of an engine with a lightened flywheel to SPIN-UP more quickly is often pointed-to as a benefit when you bang a downshift and wheel hop is reduced. In this situation, it can be said you have LESS ENGINE BRAKING. However, if your riding “style” makes this an issue, a slipper clutch may be a better alternative than a lightened flywheel; at least that’s what the factory racers think. A lightened flywheel is like a poor man’s slipper clutch in this situation.
Conversely, a heavier flywheel will provide more protection for the engine being over-revved in a ham-fisted downshift.
The ability of an engine with a lightened flywheel to SPIN-DOWN more quickly is often pointed-to as a benefit if you want the revs to die as fast as possible when you lift the throttle for a corner. In this situation, it can be said you have MORE ENGINE BRAKING. Under normal street riding conditions we tend to prefer less engine braking so we tolerate a less efficient situation where the motor then has to work harder to put more momentum into the flywheel. When racing, you don’t care about storing momentum, you just want to get around the track as fast as possible.
This enhanced ability of the engine to spin-up and spin-down also makes it less critical to match engine and drive train rpm for smoother shifts.
So, the purpose of the flywheel is to store momentum, reduce vibration and smooth out the loads transmitted to the drive train. It takes energy to first store this momentum, so if the flywheel is lighter it takes less energy and it accelerates up to speed faster. There is an opposite effect when you lift off the throttle and momentum is given up, so the revs drop slower for a heavier flywheel.
Because the engine will spin-up more quickly with a lighter flywheel, when you loose traction, modulating the throttle (especially in the rain) will be more difficult. Especially if your throttle position sensor, idle and CO are not adjusted properly. A light flywheel seem to exacerbate a poorly tuned fuel injection system. If you make 100 horsepower it’s less of a issue. Make 130 hp and it will matter a whole lot more.
The amount of weight removed from the flywheel and inner hub is proportional to this effect, although if you remove most of the weight from the outer rim area, the effect is stronger. Different after-market manufacturers of flywheels offer different weights and geometry. If lightweight is good, ultra-lightweight is better - just doesn’t apply here. Too light a flywheel can make the bike a handful to ride so a two pound flywheel for the street seems to be a good compromise to preserve some ride-ability.
A cold engine runs rough until there’s enough heat to vaporize the fuel, so until then, a lighter flywheel will be less effective in preventing stalls, especially pulling away from a uphill stop. You’ll need to rev the engine a little higher to compensate and you may find it’s a little ornery when running at light loads (3,500 rpm) in the lower gears around town. Often, your idle speed will need to be raised to around 1,300 rpm to help minimize stalling.
Lightweight Wheels Instead
Lightweight wheels don't have the stalling and drivability drawbacks of a lighter flywheel. Also, since the wheels have a much greater rotational inertia than a flywheel, weight reduction here results in a much greater improvement in acceleration (and braking) with an added benefit of reduced gyroscopic forces for improved handling. Lighter front rotors have a similar benefit. There’s even a significant difference in tire weights between brands to consider.
Larry Kelly '95 916
PostPosted: Fri Oct 05, 2007 7:17 pm
PostPosted: Mon Oct 08, 2007 8:20 am
year: 1985
mmmm you convinced me ,at next check i change belts and flywheel i think :D :D :D :D
PostPosted: Mon Oct 08, 2007 6:19 pm
PostPosted: Mon Oct 15, 2007 5:56 pm
PostPosted: Mon Oct 15, 2007 9:36 pm
year: 1985
 Post subject: Re: Lighter flywheel
PostPosted: Thu Nov 22, 2007 3:29 pm
year: 1985
http://cgi.ebay.it/ws/eBayISAPI.dll?Vie ... :IT&ih=015
do you think this flywheel is suitable for a paso???or this is inly for i.e. models???
waiting for your suggestion :D
lamps
Piero
PostPosted: Fri Nov 23, 2007 12:53 am
Don`t know any Italian but 2000 means 3phase electrics flywheel.
And it looks like that in the pic. So it wont fit.
I guess 750 has 2phase system?
Users browsing this forum: No registered users and 54 guests
