ducatipaso.org • View topic - Rear wheel axle question
It is currently Wed Oct 01, 2025 11:58 am
 Post subject: Rear wheel axle question
PostPosted: Fri Oct 26, 2007 1:32 pm
year: 1985
Hi guys i bought a 750 ss rim,and as i said before i'm planning to swap to 17 wheel on rear,now the question is what are the size of the wheel axle???
i have to machine a new one but i don't have the measure.... :confused: :confused:
many thanks
Piero
P.s.
i'm mounting also a steering dampner of a 999 and 4 piston brembo caliper with radial pump :thumbup: :thumbup:
PostPosted: Fri Oct 26, 2007 5:15 pm
if I recall correctlz its not necessarz to make a new axle. Its possible to use a new one, but you need different bearings and a new spacer.
I may be wrong but when I thought about doing that years ago I think this would have been one of the first steps.
PostPosted: Fri Oct 26, 2007 6:33 pm
What year is the SS rim? If it is an early 90's rim, it probably is already for a 17mm front axle and a 20mm rear axle. If it is a newer rim, it is for the 25mm axles. If this is the case, as Gerhard states, you will need to replace the bearings and center spacers for a 17mm front and 20mm rear axle.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Sat Oct 27, 2007 12:02 am
year: 1985
:confused: :confused: :confused:
mmmi don't understand why new bearings???
i'll investigate on the year of the rim and i give you notice when the rim arrive......
lamps
Piero
PostPosted: Sat Oct 27, 2007 7:06 am
PostPosted: Sat Oct 27, 2007 4:07 pm
PostPosted: Mon Oct 29, 2007 10:38 am
year: 1985
PostPosted: Mon Oct 29, 2007 2:44 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Nov 09, 2007 5:00 pm
year: 1985
PostPosted: Fri Nov 09, 2007 7:01 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sat Nov 10, 2007 11:34 am
year: 1985
PostPosted: Sun Nov 11, 2007 8:12 am
PostPosted: Tue Nov 13, 2007 6:27 pm
year: 1985
PostPosted: Tue Nov 13, 2007 6:34 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Nov 13, 2007 6:36 pm
Users browsing this forum: Google [Bot] and 65 guests
