ducatipaso.org • View topic - fuel injector question
It is currently Fri May 01, 2026 4:59 pm
PostPosted: Wed Oct 24, 2007 11:37 pm
 Post subject: high priced Weber injectors
PostPosted: Thu Oct 25, 2007 12:39 pm
PostPosted: Sat Oct 27, 2007 12:42 am
PostPosted: Sat Oct 27, 2007 1:58 pm
PostPosted: Sat Oct 27, 2007 5:12 pm
PostPosted: Sat Oct 27, 2007 6:38 pm
PostPosted: Sat Oct 27, 2007 6:51 pm
PostPosted: Sat Oct 27, 2007 6:58 pm
PostPosted: Sat Oct 27, 2007 7:08 pm
 Post subject: success!!
PostPosted: Sun Oct 28, 2007 6:52 pm
PostPosted: Tue Nov 06, 2007 7:26 pm
An alternative to the green injector could be the yellow IW025 injector. Static flow should be 268 cc/min, so very close to the 270 cc from the 907.
This injector was used in some fast Ford Escorts, like the Cosworth if I'm not mistaken. Any Cosworth specialist should be able to help you out with this.
Marelli part number for the IW025 is 214300200310, aftermarket supplier Meat-Doria part no. 75112025.
Michiel
