ducatipaso.org • View topic - Engine swap?
It is currently Mon Sep 29, 2025 10:39 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jun 25, 2007 3:45 pm
PostPosted: Mon Jun 25, 2007 4:39 pm
PostPosted: Sat Nov 03, 2007 12:56 pm
Do ST2 heads fit on a 907 engine?
PostPosted: Sat Nov 03, 2007 9:24 pm
Surely they fit very easily, no anykind troubles.... And they are much better quality, than original 907 heads.... If You find such "cheaply", buy them immediatelly. Most of performance come from ST2 cams!!!! :evil:
PostPosted: Sun Nov 04, 2007 1:39 am
Thx, Antti! :thumbup:
PostPosted: Sun Nov 04, 2007 2:39 pm
I bought a ST2 engine to build in my 907.
payed just € 400 for it. This is cheaper as a set of drop-in pistons and cams.
The ST2 is probably the best single spark engine.
casings ST2 are same as the 907.
problem is the electronics.
talked about this with my dealer.
I will change the wiring partly to use a newer 900SSie M16 computer, which has a programmable Eprom and use the only sensor as mouted in the ST2.
PostPosted: Sun Nov 04, 2007 8:11 pm
400€ was good deal, if it was running engine. :thumbup: You have to modifie electrics alot, cause ST2 have only one pick up and P7 have 2. That is not only thing, but anyway i wish good luck to You. :thumbup:
PostPosted: Sun Nov 04, 2007 9:21 pm
 Post subject: Re: Engine swap?
PostPosted: Sat Nov 17, 2007 11:01 am
PostPosted: Sat Nov 17, 2007 12:32 pm
U are right, Gert, i didnt remember, that ST2 have electrical tacho, but other way they should fit easily... :D
PostPosted: Sat Nov 17, 2007 1:17 pm
Who`s interested in switching the instrument panel on a Paso? :roll:
So, ST2 heads DO NOT FIT a 907. Period. :x :evil:
PostPosted: Sat Nov 17, 2007 6:33 pm
I think, very easy to find electrical tachos from internet shops.... Maybe much better quality also then.... :P
PostPosted: Sat Nov 17, 2007 6:53 pm
The ST2 horizontal head still has the boss which holds the mechanical tachodrive.
So, with a little bit of machining it must possible to mount the orginal tachodrive.
The opposit is what antti suggested, to move to electrical tacho's.
on http://www.wmd-instrumente.de/ you can find very nice combinations of Tacho and Spedo in one casing. Very nice, but expensive.
As I still are swap my ST2 engine in the 907, has anyone experience with a 907/ST2 converted to dual spark.
I done this trick on aircooled engines several times.
Ducbertus
PostPosted: Sat Nov 17, 2007 7:29 pm
PostPosted: Sat Nov 17, 2007 7:45 pm
Users browsing this forum: No registered users and 42 guests
