ducatipaso.org • View topic - On/off Ignition?
It is currently Wed Oct 01, 2025 12:03 pm
 Post subject: On/off Ignition?
PostPosted: Sun Nov 04, 2007 2:40 am
About every 3rd time I turn the key to the run position on my Paso it does absolutely nothing; as if I never turned the key on in the first place. Turning the key off and then back on again seems to fix it. Then about three or four key turns later I'm back to a dead ignition. Turning the key off and then on again fixes it, temporarily. I'm concerned that I'm gonna get hundreds of miles from home and have it happen permanently.
Any ideas what this might be?
Dave
PostPosted: Sun Nov 04, 2007 9:22 am
that is a common problem and the issue is mostly the switch itself.
http://www.box.net/shared/4evp1px5be
PostPosted: Sun Nov 04, 2007 12:22 pm
PostPosted: Sun Nov 04, 2007 3:40 pm
Gerhard - I agree; excellent writeup! Many thanks! I'll try it today and let you know how it goes.
Dave
PostPosted: Sun Nov 04, 2007 5:10 pm
note, the tricky part is to push the lower (white) part, the one with the cables coming out of it, back in place. It needs some force to be pushed into place but it`s fragile and may break. If you use a screwdriver for this use an old large one, one that does not have any sharp edges anymore and try to press in a cross pattern (like when tightening wheel nuts).
The risk is to break that part and if you do ... :mad: :mad: :mad: :sad: :sad: :sad:
PostPosted: Sun Nov 04, 2007 8:43 pm
PostPosted: Sun Nov 04, 2007 9:02 pm
PostPosted: Fri Nov 09, 2007 9:07 pm
George Betzhold
Scottish Woods Log Cabin Resort
Murphy, NC
PostPosted: Sat Nov 10, 2007 8:50 am
PostPosted: Sat Nov 10, 2007 9:19 am
PostPosted: Sat Nov 10, 2007 5:15 pm
George Betzhold
Murphy, NC
PostPosted: Sat Nov 10, 2007 6:54 pm
PostPosted: Sat Nov 10, 2007 8:03 pm
George Betzhold
Murphy, NC
PostPosted: Sat Nov 10, 2007 9:08 pm
George Betzhold
Murphy, NC
PostPosted: Sun Nov 11, 2007 1:51 am
Users browsing this forum: No registered users and 62 guests
