ducatipaso.org • View topic - Timing Belt Install Question.
It is currently Fri Nov 14, 2025 2:11 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: Timing Belt Install Question.
PostPosted: Fri Nov 02, 2007 11:42 am
Reading older posts on this subject makes it sound so'oo easy, a 45 min job, ha! I seem to be having some difficulty. :oops:
The belt doesn't just slip over both gears. It's very tight! Do you need to rotate the engine while stretching the belt on? I had a fair bit of trouble removing the belts, so much so in-fact, that they got damaged when being removed. Just to state the obvious, both idler and tension bearings have been removed.
PostPosted: Fri Nov 02, 2007 1:02 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Sat Nov 03, 2007 1:49 am
Thanks for the reply. I am trying, to no avail, to insert a picture of my timing gears. They have a washer on them which is the same size as the gear, which prevents the belt from smoothly pushing into place. Arr
How do I insert a picture to show you what I mean?
PostPosted: Sat Nov 03, 2007 1:48 pm
First, you'll need a host to link to the pictures. http://www.photobucket.com has free picture hosting. Sign up for a free account and then follow the rest of the instructions.
The pictures you send must be on your computer.
Log into your photobucket.com account.
Where it says " Add Pictures " , click on multiple pictures ( click on how ever many you'll be adding ) and then click " browse".
You'll need to go where you saved your pictures, usually " MY PICTURES "
( I use Kodak software, so I click on "Kodak Pictures" inside of "my pictures")
Click on the picture ( single pic ) that you want to add.
Repeat as many times as necessary.
Hit " submit ".
It will let you know when the pictures are successfully downloaded.
Then go under the picture and "copy" the [img]picture%20description%20in%20here[/img] address.
That is what you copy into the thread post.
PostPosted: Sun Nov 04, 2007 9:14 am
When I change the belts, I borrow the correct tool to remove the pulley net from my local bike mechanic. You also have to make sure the woodruff key that locates the pulley doesn't slip out of position when fitting the pulley. Make sure you do it with plenty of light. I normally get the mechanic to replace the belts and check the valve clearances at the same time.
When I fisrt got my Paso about 11 years ago I changed the belts without the special tool and vowed never to do it again. I still don't know how I did it, but I know there was a lot of bad things I said about Ducati engineers that day :mad: :mad: :mad:
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Sun Nov 04, 2007 11:06 am
I've changed a lot of timing belts in my like as a car mechanic (one or two lives ago :laugh: ) You need strong nails in your fingers to pull off belts from their seat! Otherwise, belts could never be able to stay there while an engine is running at 9500 rpms!
To make the work easier, you can take the fixed bearing away and loose the tension bearing at all.
Another tip: If the fixed bearing is the "old solution" (a pair of std bearings), it might be the right time to switc to a "recent solution",
the special bearing installed on the newer desmodue starting from earlier pasos
PostPosted: Sun Nov 04, 2007 12:05 pm
PostPosted: Mon Nov 05, 2007 4:30 am
PostPosted: Mon Nov 05, 2007 5:35 am
Sorry guys just checking out my new found photo input skills, thanks to h1a.
PostPosted: Mon Nov 05, 2007 10:28 am
PostPosted: Mon Nov 05, 2007 4:29 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Nov 05, 2007 5:43 pm
PostPosted: Mon Nov 05, 2007 6:09 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Nov 05, 2007 6:13 pm
PostPosted: Mon Nov 05, 2007 6:53 pm
