ducatipaso.org • View topic - Clutch hose routing.
It is currently Fri Nov 14, 2025 12:06 pm
 Post subject: Clutch hose routing.
PostPosted: Fri Nov 02, 2007 12:45 pm
I have overhauled the clutch pump and slave cylinder and bleed the system. All is working fine however I can't remember which way the hose was routed. Does the hose pass in front of or behind the head stem? I currently have it passing forward of the head stem however it appears that at full left lock the hose rubs more than I think it should. I feel that if I were to make it pass behind the head stem, then at full left lock it would have some fairly big bends on it however I could be wrong. I should have checked it out before bleeding or taken more notice prior to disassembly but!!!
PostPosted: Thu Nov 08, 2007 2:11 am
PostPosted: Thu Nov 08, 2007 1:40 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Nov 09, 2007 12:47 pm
PostPosted: Fri Nov 09, 2007 1:38 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sat Nov 10, 2007 3:04 am
