ducatipaso.org • View topic - left switch block query
It is currently Mon Apr 27, 2026 8:00 pm
 Post subject: left switch block query
PostPosted: Thu Nov 15, 2007 9:58 pm
 Post subject: Re: left switch block query
PostPosted: Fri Nov 16, 2007 8:04 am
PostPosted: Mon Nov 19, 2007 9:36 am
Thanks for the information. It helps alot to ask the right people. Yes I am keeping an eye on ebay 907 parts. Someone has obviously dismantled one so there are a few things for sale at present.
For me to purchase parts from US or Europe is quite expensive with high freight costs so I will try closer to home. I think the dash on ebay is used, the description suggests it would be ok for parts.
Graeme
PostPosted: Tue Nov 20, 2007 1:44 am
I have a left hand switch assembly that I will sell. I took it off my 907IE last year to replace with the Euro version. It is in perfect working order, let me know if interested. My zip is 01748 if you want to get a shipping quote.
PostPosted: Tue Nov 20, 2007 5:14 am
May I ask what the difference is between what you have for sale and the Euro version?
I require the usual lights, indicator, high / low beam, horn and choke.
I can't see how there can be different versions for different parts of the world.
But then there is stacks of stuff I don't know so its probably in that lot.
However I am interested. I assume you are in the US.
Graeme
PostPosted: Tue Nov 20, 2007 9:32 am
PostPosted: Wed Nov 21, 2007 12:21 am
I didn't realize you are in New Zealand! The extra switch is to the right of the hi/lo switch on the Euro, I wired that switch so I can run 1 low beam, two low beams, or both highs with the dual headlight conversion. Anyway the Euro switch is Ducati #036138456, it was $105 US last year. Good luck!
Art
