ducatipaso.org • View topic - Stand Assembely...Does this look right?
It is currently Mon Sep 29, 2025 6:58 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Stand Assembely...Does this look right?
PostPosted: Sun Nov 18, 2007 8:47 pm
The one on my '87 Paso 750 does not have the suicide-stand function. I don't know if this is original or not, but it looks like it simply has a longer spring and has that metal plate removed.....
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Sun Nov 18, 2007 9:41 pm
PostPosted: Mon Nov 19, 2007 2:26 am
Here's a link to the Ferracci item:
http://www.ferracci.com/store/cart.php? ... tail&p=405
PostPosted: Tue Nov 20, 2007 2:32 am
Numerous options available for me, cheers. :D
PostPosted: Tue Nov 20, 2007 4:08 am
PostPosted: Fri Nov 23, 2007 6:19 am
PostPosted: Mon Nov 26, 2007 12:22 pm
the ballast resistors used in some cars (integrated with the coil or external) are there because the ignition system is designed to work satisfactorily when there is less than 12 volts available to it. This happens when the car is being started and the high current draw from the starter motor reduces the terminal voltage at the coil (maybe to 8-9 volts). When the engine is running the terminal voltage is back up to at least 12 (more like 13.6-14.4 as the alternator is generating power). The resistor in the primary coil circuit drops several volts across it so the coil only sees it nominal design voltage of say 9V. In this type of ignition system, if the resistor is bypassed when the engine is running the coil may burn out as the higher voltage will force too much current through the coil.
This was mainly used in older cars with points ignitions. Newer vehicles with electronic ignitions typically don't use ballast resistors with coils.
PostPosted: Mon Nov 26, 2007 5:02 pm
Thanks for that dave906. :wink: I thought it went something like that but couldn't quite remember as it was a while ago when I last tinkered with older cars like these. I'm guessing the PASO's don't have these resistors in the circuit and so the modified power supply mod for the coils could only be a good thing yer?
PostPosted: Tue Nov 27, 2007 11:08 am
Hi Kirk
Yes the power supply mod on this site means that the coils get a more direct supply from the battery, but also that they are not hanging off about 200m of wiring in the loom suffering excessive voltage drop from the current draw due to other loads and dodgy connections thru the ignition switch, kill switch and extra connectors.
Dave
PostPosted: Tue Nov 27, 2007 11:37 am
Hey Dave,
Thanks for that. Have you done the mod yourself and if so was there any noticeable improvement gained? I should imagine if you had any dodgy wiring there, then it would have to improve things a lot. A fairly easy mod though which would alleviate the possibility of that side of things causing a problem I guess.
Kirk
Users browsing this forum: No registered users and 30 guests
