ducatipaso.org • View topic - Mikuni jets
It is currently Wed Oct 01, 2025 4:25 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Mikuni jets
PostPosted: Mon Nov 26, 2007 9:52 pm
You bet, as Nicola told, the Weber carb also makes go the Paso faster :!: :!: :!:
PostPosted: Tue Nov 27, 2007 5:30 am
... with "flat spot"... :twisted:
PostPosted: Tue Nov 27, 2007 6:45 pm
Be careful, Dyna jet numbering (124,128 for stage 1) is NOT the same as Mikuni.
A 140 Mikuni I believe is 1.4 thou of an inch - Dyna jet use their own measuring system.
Don't forget that the needles with the Dynajet kit are a totally different profile designed to work with dyna jet mains.
I used 124 but with open exhaust pipe and pod filters is wasn't enough. The 128 works well. No flat spot.
Needle clip 3 positions down and idle jet 37.5 (I mucked around for ages with 40.0,42.5 - but they are way too rich)
Float level 14mm
AND SYCH THE CARBS !!!!!!!!!!!!!!!!!!!!!!! :wink:
Tony
PostPosted: Tue Nov 27, 2007 7:28 pm
Very usefull info!!! So, it seems, that normal Mikuni jet sizes are totally different, than Dynojet kit jets! Just that can explane that big diffrence between "sizes"... :? Those original needes were also totally different looking(much thicker), than Dynojet needles(what i put inside with new lighter Dynojet springs). So, seems, that i have to open them again and put those Dynojet jets. I must propably look jets closer by eyes to see, is there big difference.... THANKS! :) Sync is very easy job to me :lol:
PostPosted: Wed Nov 28, 2007 12:45 am
PostPosted: Wed Nov 28, 2007 5:16 am
Thanks Gert, Nowbody told this earlier? :evil: How about smaler sizes, like Dynojet 128 and 124 compared to Mikuni jets?
PostPosted: Wed Nov 28, 2007 6:45 am
You can tell from the chart that the rate flow/diameter ratio is liniar. so you can calculate the required size.
So, DJ 128 should be Mik. # 136.5.
PostPosted: Wed Nov 28, 2007 9:01 am
PostPosted: Wed Nov 28, 2007 3:10 pm
Sorry, Gerhard, i missed that Your early post, sorry... :oops: And i missed also that comparation chart, or was it link to it.... :oops:
As You know, i am virgo(very accurate), but not so accurate, as Germans :lol:
