ducatipaso.org • View topic - Gear indicator and led revcounter
It is currently Thu Oct 02, 2025 12:20 am
 Post subject: Gear indicator and led revcounter
PostPosted: Mon Nov 19, 2007 1:07 pm
year: 1985
Hy guys as i said in another discussion i mounted in this past week end this two very necessary objects :D :D :D
now the gear indicator function normally but there are problem with the rev counter....
after connecting the red-positive and black to ground,there are two wires coming out from the tacho orange and brown....i don't know what of these take impulse from the engine and i make tests but when i connect orange wire to pick up positive cable it lights on all led in sequence but this led don't follows motors rpm :oops: :oops: :oops: when i connect brown wire to cable sometimes all the led lights together :shock: :shock: :shock: :shock:
do you have any ideas???al suggestion are accepted
many thanks
lamps
Piero
 Post subject: Re: Gear indicator and led revcounter
PostPosted: Mon Nov 19, 2007 1:18 pm
as both are aftermarket parts do you have an electrical/installation scheme of both parts to look at or did they come without any documentation ?
If so knowing model and brand may help.
G:
PostPosted: Tue Nov 20, 2007 10:17 am
year: 1985
i read very very little wroted on the circuit datatool and that's the brand!!!! :) :) :)
i found the site and the manual all is ok today i finsh to mount and i give you news :mrgreen: :mrgreen:
PostPosted: Tue Nov 20, 2007 11:37 am
pls. make pictures of the mechanism of the gear level indicator. I`d like to know how you solved that with the microswitch and so.
G:
PostPosted: Tue Nov 20, 2007 2:47 pm
Here gear indicator (red LED seven segment)coast "about" 86€ and its connected to both speed and rpm circuits, nothing mechanical. 8)
PostPosted: Tue Nov 20, 2007 7:20 pm
interesting ! I never saw this type, only know the old one that required microswitches at the gear lever.
who`s interested ... ie.
http://www.biketronix.info/Shop_NL/index1.html
http://www.riderstation.com/DG8_Instr_Feb_03.pdf
(regarding connections these two seem to be already quite different. If you look at the first link and then "Handleidingen", then whatever model one can see that it uses a wheel sensor, the other one doesn´t)
G:
PostPosted: Wed Nov 21, 2007 8:51 am
year: 1985
I have a new digital dashboard and the gear indicator needs digital speedo,there is also a tipe for anlogic speedo but is much expensive... :evil: :evil:
i'll post photo when i reassemble bikelamps
Piero
PostPosted: Fri Nov 30, 2007 7:12 pm
I am almost 100% convinced I will be installing one of these on my cafe bike to reduce the amount of clutter above the triple tree.
http://www.trailtech.net/computers.html
I'm thinking about the Vapor plus the dashboard with indicator lights so that my charging circuit functions as it should. Just like this:
The whole thing can be done for about $150 :!:
PostPosted: Fri Nov 30, 2007 7:21 pm
Cheap FOR YOU! :) But i think, not so cheap to us EU guys... If someone know seller here in EU, then it "can be" also cheap for us... :twisted: Anyway, it looks quite good! 8)
PostPosted: Fri Nov 30, 2007 8:30 pm
PostPosted: Fri Nov 30, 2007 8:55 pm
:mrgreen: Thanks, Jon! :D Soon i have DD headlight kit and new nice dashboard to my Ducatis... :lol: (joking little)
PostPosted: Fri Nov 30, 2007 9:30 pm
I was once thinking about the Aprilia RSV Mille instruments as the shape of the whole panel is somewhat like the one of the Paso, but I like it as it is (specially the fuel indicator). Plus I think it`s quite hard to adapt unless you`re using 17" wheels etc.
PostPosted: Fri Nov 30, 2007 10:00 pm
PostPosted: Fri Nov 30, 2007 10:05 pm
Everything is relative so, here in Italy, the Aprilia stuff is much cheaper than the Ducati stuff.
PostPosted: Sat Dec 01, 2007 12:58 am
Users browsing this forum: No registered users and 59 guests
