ducatipaso.org • View topic - steering damper exmple
It is currently Mon Mar 09, 2026 3:58 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: steering damper exmple
PostPosted: Mon Dec 03, 2007 3:53 pm
Steering damper MUST BE ADJUSTED to quite lightly mode!!! I have heard this from my friend(888 SP4 owner) and he have played alot with these things. He use Öhlins damper,what is adjustable. ...something good from Sweden... :mrgreen:
PostPosted: Thu Dec 06, 2007 2:09 pm
year: 1985
Sorry for the late :) :)
these are the photo of the damper's movement
i hope this help :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Thu Dec 06, 2007 2:39 pm
so this is where it turns ?
I would have done it this way:
Sorry, I`m no Photoshop artist :)
PostPosted: Thu Dec 06, 2007 4:46 pm
It does appear that the swivel joint has the range of motion needed. Yes the bolt in the vertical position would have been more like the stock install. This part is not structural so it look to be ok.
PostPosted: Fri Dec 07, 2007 12:41 am
the vertical pivot bolt would be nicer.
spherical bearings are strongest and will last longer in load applications in the central axis.
of course, a steering damper sees 99.9% of it's time in the "straight ahead" position; you're in trouble if you have the steering at lock at any speed - unless you're into controlled power-slides...
so long as the strength is there when the steering is central is all you really need for the damper to be effective.
you need to be able to turn lock to lock (which you appear to have)
and
you appear to have used the full travel of the damper.
happy riding.
