ducatipaso.org • View topic - Swingarm Brake Bracket Pin
It is currently Mon Sep 29, 2025 11:32 pm
 Post subject: Swingarm Brake Bracket Pin
PostPosted: Thu Dec 06, 2007 9:39 pm
Anyone here have a picture and dimensions of the swingarm pin for the rear-brake, caliper bracket? On the parts list, it is #037740070. This is the pin that is bolted to the inside of the swingarm to prevent the caliper bracket from rotating. I picked up a used 907 swingarm needing some work and it is missing this piece. The pin is no longer available from Ducati, so I was wondering what it looks like and it's dimensions so I can make one. Thanks!
Also, anyone have the left swingarm end cap that the axle adjustment bolt goes through (part #37310041A)? This is still available, but at $35 plus shipping, it is more than I spent on the complete swingarm.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
 Post subject: Re: Swingarm Brake Bracket Pin
PostPosted: Thu Dec 06, 2007 11:42 pm
Isn`t that the same pin on the 93-99 Monster swing?
Ought to be avaliable.
PostPosted: Fri Dec 07, 2007 10:24 am
if it is the same as on a Monster swingarm, then it is the same as on an 888 also.
btw I would have all the parts you need but as a set and only shipment would cost more than what they ask for that part in US.
PostPosted: Fri Dec 07, 2007 11:35 am
is is noticeable I currently have time ? :D
the bolt is a grade 8.8.
PostPosted: Fri Dec 07, 2007 1:11 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Dec 07, 2007 1:33 pm
the pictures and measurements are made from a spare 907ie swingarm I`m keeping for similar reasons as you do :)
 Post subject: Re: Swingarm parts ....DESMO DEMON
PostPosted: Fri Dec 07, 2007 10:29 pm
RE Rear caliper bracket , 907 , Check US ebay - RPM CYCLE PARTS.....$30.00. BUY NOW. Hope its OK, .......Marty
PostPosted: Sat Dec 08, 2007 11:31 am
PostPosted: Sun Dec 09, 2007 2:31 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sun Dec 09, 2007 2:34 pm
PostPosted: Mon Dec 10, 2007 2:49 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Users browsing this forum: No registered users and 58 guests
