ducatipaso.org • View topic - Mirrors
It is currently Sun Apr 26, 2026 4:18 am
 Post subject: Mirrors
PostPosted: Sat Nov 24, 2007 8:00 am
When I bought my Paso in July, one of my first postings to this forum was to ask about mirrors. I think I have found an ideal solution for mirrors to use when riding with a passenger.
When I was looking for clutch master cylinder parts, I saw that Brembo has clutch lever + master cylinder units with mirror mounts. Assuming that the mirror mounts are just threaded holes that take standard mirrors, and that they also have the right side brake lever + master cylinder units with mirror mounts, it seems that replacing the stock units with these would be a good solution for adding mirrors for riding with a passenger, or for touring. When going for a ride with a passenger, just add a second set of ordinary mirrors. Afterwards, remove the mirrors and put plastic caps into the mirror mount holes. If you ride alone most of the time, this seems like an excellent solution.
 Post subject: Re: Mirrors
PostPosted: Sat Nov 24, 2007 1:18 pm
Those mirrors' mounts can be found also as spare parts.
But, I think the Paso with them wouldn't look too good :mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: Sun Nov 25, 2007 9:25 am
some pasos have oem mirror mounts in pumps bracket.
If you find such a mount on a spare brake :| pump, be sure it's a 15 or 16 mm piston diameter, as it might be the 13mm suitable for monster 600
PostPosted: Sun Nov 25, 2007 9:41 am
Have to put guys now "to ground":
I have just those threads in lever systems, that there is that "possibility" to put some aftermarket mirrors, BUT i tested it some years ago and problem is, that those aftermarket mirrors hit to front fairing inside surface, when turning handelbars to more right/left! I had one very good looking carbon fibre mirror pair, but i realized, that at least that didnt function at all... :twisted:
PostPosted: Sun Nov 25, 2007 1:42 pm
We are condemned not knowing what's happening at the back.
Only we can glance at the legs (it would like to think nice) of our passenger :lol: :lol: :lol: :lol: :lol: :lol: :lol: .
PostPosted: Sun Nov 25, 2007 3:23 pm
Let´s hope that the passenger has nice legs... :roll: :roll: Because that´s what is
showing in the mirrors with one on the back. :mrgreen:
PostPosted: Sun Nov 25, 2007 6:09 pm
We only wait what Antti has to tell about, at least if he drunk some Koskenkorva :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: .....
PostPosted: Sun Nov 25, 2007 7:15 pm
PostPosted: Sun Nov 25, 2007 7:53 pm
PostPosted: Mon Nov 26, 2007 8:01 am
Francesco,
Hey your avatar now moves. An added benefit of this new site arrangement?
Fraser.
PostPosted: Mon Nov 26, 2007 5:20 pm
PostPosted: Mon Nov 26, 2007 9:24 pm
PostPosted: Fri Dec 07, 2007 2:27 am
You could use a bar end like the CRG Hindsight 3" mirror. The bar end would have to be drilled if you want them out beyond your hands, you know for big chested passengers :lol:
PostPosted: Fri Dec 07, 2007 2:36 am
Check out this site fto see these mounted on other Ducatis, some bolt-on!
http://www.bevelheaven.com/stuff-for-sale-mirror.htm
