ducatipaso.org • View topic - Another question about clocks!
It is currently Tue Sep 30, 2025 10:43 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Another question about clocks!
PostPosted: Fri Dec 07, 2007 9:58 pm
PostPosted: Sat Dec 08, 2007 11:12 pm
Yep i reckon 120 ohms too :thumbup:
PostPosted: Sun Dec 09, 2007 12:16 am
paso 750 thanks a bunch. There are some really good photos here which will hopefully get my clock ticking once again. This has most probably inspired many others to investigate further their clock problems and possibly get theirs working once again. "You da man!" :thumbup:
PostPosted: Sun Dec 09, 2007 9:15 pm
Please let us know how you get on - I'm in the queue for a clock fix
PostPosted: Sun Dec 09, 2007 11:21 pm
PostPosted: Mon Dec 10, 2007 5:20 am
PostPosted: Sat Dec 22, 2007 7:01 am
PostPosted: Sat Dec 22, 2007 6:53 pm
If someone needs it, let me know.
PostPosted: Sun Jan 20, 2008 11:21 am
if you wish to save all the fiddling around, i believe the Paso clock can be replaced by fitting the printed circuit board from some Fiat models such as the Mirafiori, Tipo and Jaeger.
PostPosted: Tue Jan 22, 2008 9:58 am
I have heard, that Fiat Ritmo have same clock, but outside looks only diffrent, so have to add parts together. I ahvent seen, but i have heard! :mrgreen:
PostPosted: Wed Jan 23, 2008 9:28 pm
Very many FIAT group cars had the same electrics of the Ducati of the same era.
Automotive pick up (on the flywheel) thermostat, ECU, clock etc. were employed on the Ducati.
PostPosted: Thu Apr 10, 2008 7:07 pm
So, which lead kills the clock? Which wire to cut?
If you don`t want a running clock.
PostPosted: Sat Apr 12, 2008 10:26 am
Its an orange wire (mine looks more orangey-red) that hooks into the 12 volt supply near the regulator. It's crimped to the main heavy red wire that goes from the regulator back to charge the battery. At the instrument panel end, it is the top wire (pin 1) into a 6 pin connector in the middle of the back of the instrument panel.
You could cut the wire and insert an in-line switch behind the instruments, or under the seat.
Dave
PostPosted: Sat Apr 12, 2008 12:27 pm
PostPosted: Wed Jun 15, 2011 11:14 am
