ducatipaso.org • View topic - Marelli Ignition "pickup"
It is currently Thu Mar 12, 2026 2:18 pm
 Post subject: Marelli Ignition "pickup"
PostPosted: Sun Dec 02, 2007 5:13 pm
On the Paso/750 sport with a Digiplex igniter there is a single Marelli pickup that is triggered by flywheel.
Does anyone know the Marelli part number.
I believe it is a SEN 8D.
Thanks in advance.
bucbean
 Post subject: Re: Marelli Ignition "pickup"
PostPosted: Sun Dec 02, 2007 7:08 pm
I don't know that number, but if you're in Europe, you can easily find it, since the same unit is fitted on many FIAT group cars, as FIAT UNO, Lancia Y10, etc.
PostPosted: Sun Dec 02, 2007 9:09 pm
Thanks for the reply!
Yes I realize....in fact the device is called an "Inductive Speed/RPM sensor"
It is used in many applications...automotive, motorcycles, race cars....ignition, electronic tachs etc.
The problem is it comes in a lot of variants....and I can't find which variant was used on this model Ducati.
bucbean
PostPosted: Sun Dec 09, 2007 6:18 am
Bucbean,
The pickup on my Sport looks almost identical to the one for my ST2. I dare say, they may interchange. They were both made by the same company. You can often find them on ebay for cheap.
One thing a bunch of ST owners found out was that the gap to the flywheel was set way too large. When set to the proper gap it started and ran much better . So check your gap before you set out to change the sensor.
Phil
PostPosted: Sun Dec 09, 2007 2:30 pm
Gap should be very close 0.75-0.80 mm. :smoke:
Ps. There is 2 and 3 wire pick ups(look close connector). They add later that 3rd wire for grounding.
PostPosted: Sun Dec 09, 2007 2:39 pm
PostPosted: Sun Dec 09, 2007 2:48 pm
As You can see, i have started to enjoy my rest lifetime... :smoke: :beer:
PostPosted: Sun Dec 09, 2007 3:01 pm
PostPosted: Sun Dec 09, 2007 5:10 pm
Not so much today... :mad:
PostPosted: Sun Dec 09, 2007 11:07 pm
So, I can understand your annoyance, and the reason because you're smoking so much...
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
