ducatipaso.org • View topic - Help! wiring radiator, fan, and termostatic switch
It is currently Thu Oct 29, 2026 11:02 pm
 Post subject: Help! wiring radiator, fan, and termostatic switch
PostPosted: Tue Dec 04, 2007 8:11 pm
I have a 1990 Paso 906. The bike has no wires run on the cooling system currently. Need a picture sent to me for routing please. I have the wiring diagram but it is not sufficient. Where do the two wires go from the radiator itself? Where do the wires go from the termostatic switch? Where do the two wires go from the instrument panel? Where do the wires go from the fan? If any one can send me some pictures of a 906 or help me in anyway it would be much appreciated. The owners manual tells of routing but I'm not sure what the components physically look like. How can I test to see if the cooling system is operational? Thanks for helping.
 Post subject: Re: Help! wiring radiator, fan, and termostatic switch
PostPosted: Tue Dec 04, 2007 9:44 pm
did you check this wiring plan ?
The (pink) cable that passes the thermostatic switch comes from the fuse box and goes to the fan. Not sure what you mean by wires from radiator and which colour do the wires of the instrument panel have that you refer to ?
Regarding testing, when you short the thermostatic switch the fan should come on.
When you measure resistance of the switch (wires disconnected) I suppose you should measure nothing. If you remove it and hang it in almost boiling water you should measure a short. Maybe you can also heat it up with a lighter but then you cannot tell at all at what temperatur it switches.
PostPosted: Wed Dec 05, 2007 4:42 pm
The radiator has a switch that is attached to the bottom left side, it has two flag terminals for wires to plug into it. I was looking for a brown/black wire but didn't find it yet in the harness... I'll get back to it...and post the colors of the wires I have in question..coming fron the instrument panel. Thanks for the info
PostPosted: Wed Dec 05, 2007 7:46 pm
PostPosted: Wed Dec 05, 2007 8:04 pm
Btw, seems, that 906 have quite different routed lines, as 907 have... :smoke:
PostPosted: Wed Dec 05, 2007 8:22 pm
not really, it`s the same but they changed 2 tubes to one and changed the position of the switches
907i.e.
PostPosted: Thu Dec 06, 2007 7:33 pm
What color are the wires coming off of the switch on the lower left side of the radiator? Where do they go to from there? Thanks again for your help.
PostPosted: Thu Dec 06, 2007 9:03 pm
anyone with a 906 who can answer this ? According to the pic above there`s nothing directly on the radiator.
If there is a switch it could be either the temp switch for the fan or the sensor for the temp gauge. I couldn`t think of anything else.
Do you have the sensors 3 and 5 as on the first pic above ? If you find only one, the second one is probably the one you have in your radiator.
PostPosted: Wed Dec 12, 2007 4:41 pm
Yes I have #3 and #5 on the diagram. Temp sensor and switch. The sensor in question is screwed directly on the lower left of the radiator itself. ANYONE HAVE A 906 PASO ?? Please help, WHAT COLORS are the wires that come off of that switch ( or did someone put a diffrent radiator on this bike before I bought it ?! ) :banghead:
PostPosted: Thu Dec 13, 2007 10:58 am
It can be, that radiator have changed to Your bike later. I think, that Ducati used same radiator in 906 and 907 and in my 907 sensors are just in that tube, where they are in that pic. Sorry, cánt help more... :dunno:
PostPosted: Thu Dec 13, 2007 12:34 pm
I have a 1990 906.
There are two pink heavy gauge wires (bullet connectors) from switch 5 (the radiator fan temp switch), and one light gauge Brown/Black wire (spade connector) from switch 3 (the water temp sensor). The body of switch 3 goes to earth via the engine.
There are no other switches direct from the radiator. My radiator is original.
Dave
PostPosted: Thu Dec 13, 2007 4:37 pm
Thanks Dave,for clearing up the cooling system issue. :beer: I'll just have to order a few more parts now and she should be back on the road. Starter solinoid , instrument panel , and fork seals.
PostPosted: Sat Dec 15, 2007 10:16 am
No worries Snake. Correction to the pink wire connections - they are spade connectors as well, not bullet...a brighter torch did the trick.
Dave
