ducatipaso.org • View topic - wire color code for left switch
It is currently Mon Sep 29, 2025 2:37 pm
 Post subject: wire color code for left switch
PostPosted: Mon Dec 17, 2007 11:03 am
Hi all,
I have acquired a universal switch to replace a damaged original on my 907.
However after looking at the excellent 'Wiring_907_colour.jpg' file and looking inside my old original switch I notice that some of the wire colours are different.
Does anyone know which color wires are used to do the following?
Headlight main wire
Low beam
Park light
Pass / highbeam
I have figured out the turn signals and horn ok.
Graeme
New Zealand.
 Post subject: Re: wire color code for left switch
PostPosted: Thu Dec 20, 2007 10:38 pm
I did this on my 900SS and it was quite a pain in the a$$. I ended up cutting the old switch plug off and soldering it to the new wiring after tracing every wire.
PostPosted: Fri Dec 21, 2007 2:30 pm
Horn - gray - #1
Lights feed - grn/blk - #2
Right dir - red - #3
Hi Beam - wht - #4
Prk feed - grn - #5
Turn feed - blk - #6
Lo Beam - blk - #7
Prk - yel - #8
Left dir - blue #9
Numbers go left to right across the keyed side of the connector, then across the middle row, then top row. Good luck,
Art
Users browsing this forum: No registered users and 115 guests
