It is currently Fri May 01, 2026 8:44 pm
[ 3 posts ] |
| Author |
osapitacud
Post subject: wire color code for left switch Posted: Mon Dec 17, 2007 11:03 am |
Joined: Mon Mar 05, 2007 12:00 am Posts: 18 Location: New Zealand
Hi all,
I have acquired a universal switch to replace a damaged original on my 907. However after looking at the excellent 'Wiring_907_colour.jpg' file and looking inside my old original switch I notice that some of the wire colours are different. Does anyone know which color wires are used to do the following? Headlight main wire Low beam Park light Pass / highbeam
I have figured out the turn signals and horn ok.
Cheers, Graeme New Zealand.
| Top |
jcslocum
Post subject: Re: wire color code for left switch Posted: Thu Dec 20, 2007 10:38 pm |
| paso grand pooh-bah |
I did this on my 900SS and it was quite a pain in the a$$. I ended up cutting the old switch plug off and soldering it to the new wiring after tracing every wire.
| Top |
Shelboss
Post subject: Re: wire color code for left switch Posted: Fri Dec 21, 2007 2:30 pm |
Joined: Wed Sep 06, 2006 12:00 am Posts: 101 Location: USA
Horn - gray - #1 Lights feed - grn/blk - #2 Right dir - red - #3 Hi Beam - wht - #4 Prk feed - grn - #5 Turn feed - blk - #6 Lo Beam - blk - #7 Prk - yel - #8 Left dir - blue #9 Numbers go left to right across the keyed side of the connector, then across the middle row, then top row. Good luck, Art
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 25 guests |
