It is currently Fri May 01, 2026 1:28 pm
 Post subject: air filter
PostPosted: Wed Jan 09, 2008 2:50 am
Happy New Year.Im using the cold months in the USA to work on my 1992 907IE..Bike runs great but has no service records so Im doing all the basic stuff(Ill have dealer do the belts and valves).I removed the tank and I thought it was strange after disconnecting the 2 fuel hoses and breather hoses no gas came out and the tank was full??I ended up with siphon and removing gas that way.Whats up??Also when I opened up the air filter box the filter that was in was a Fram PA7059 and I cant find that part anywhere.Any other after market air filters.Thanks all..g
 Post subject: Re: air filter
PostPosted: Wed Jan 09, 2008 4:33 am
Happy New Year! I just finished a 1" extension to my 907 kick stand, now I'm working on the Norton. The Ducati has an in-tank fuel pump, that's why the gas doesn't leak out. You may want to change the fuel filter if you don't know when it was done last. K & N makes an air filter for the bike, check online or call BCM in N.H.
