ducatipaso.org • View topic - 750 Paso front brake adapters to swap 320 rotors to M1R
It is currently Mon Sep 29, 2025 9:08 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 750 Paso front brake adapters to swap 320 rotors to M1R
PostPosted: Fri Jan 25, 2008 7:06 am
Yes, I had use new caliper (65mm). I have two types and choice model to made the simplest adaptor.
Actually, it's easily to find 65mm caliper in ebay.
Bye
________________________
Christian
Paso 750
Monster 900 carbu
999s 2005 Xerox
http://www.zattol.com/perso
PostPosted: Fri Jan 25, 2008 12:25 pm
I have already black coloured more rare 907IE(91') Brembos(with steel braided lines) for swapping them same time, as i do that 17" conversion to my 750 Paso with original 750 M1R fork. Now running with same brake system, but another adopters to fit original 16" Oscam wheel with original rotors. With 17" conversion i put also 320mm rotors(from 92 modell 907IE).... Still need adopter measurements. It can be, that nowbody have done same adopters, as i need next... :mrgreen:
PostPosted: Fri Jan 25, 2008 5:47 pm
I think that should be easy. Take the 65mm adapter as basis
and just shorten the hole distance along the red line to 40mm. (the left/upper mounting hole of the brake caliper should stay were it is)
PostPosted: Fri Jan 25, 2008 8:52 pm
Thanks, G-man! It can be, that i have to do just so, but i have to do some measurements first from my ST calipers. Propably that "red line" is in same place in both calipers, black ones and new ones. But wondering, cause those black ones are designed for 300mm(91*907IE) rotors and those "golden" ones are for 320mm rotors :?:
Anyway i still wait, if someone have made such adopters, cause i am not in any hurry to make 17" conversion, i have still "not used 16" Michelins" in my 750 Paso....
Thanks, Gerhard :thumbup:
PostPosted: Fri Jan 25, 2008 9:44 pm
PostPosted: Fri Jan 25, 2008 10:14 pm
hi antti,
i've got those adapters.
they are to fit to m1r forks (750 paso) and brembo 17" wheels with goldline 40 mm brakes.
i am busy right now to change the m1r with a paioli from a laverda.
i hope i've got the time for it this weekend, but i can give you the measurements for it
:thumbup: greets, ab.
PostPosted: Sat Jan 26, 2008 10:39 am
Thank You, Zap very much already! :thumbup:
Frankie: i am wondering, that is there any diffrence to make adopters to 300mm rotors(like in 91 907), or 320mm rotors(like in 92 907 and Supersports, etc.) cause i start to use normal 17" Ducati front wheel(from 91 907) in my 750 Paso with 320mm rotors.... I know very well, that those black ones have same 40mm holes , as older golden line Brembos..... and later have that 65mm distance.
I try to find out, that 320mm rotors dont hit to calipers after making adopters !!!!...and they make pressure just to right part of brake disk.. THAT is "the point"..... I think all have same offset, so that shall not be any problem.... :smoke:
PostPosted: Sat Jan 26, 2008 10:46 am
PostPosted: Sat Jan 26, 2008 6:36 pm
From wich model the forks are, i do not know but the triple tree is from a formula 750.
I already have made much adaptions like shortening the steering stem by 2.5 cm and recenter the wheel with bushes and dye more threat on the paso axle etc. :wacko:
Antti i will pm you.
PostPosted: Sat Jan 26, 2008 7:01 pm
Zap,
pls keep me updated on this as it seems we have the same fork. Did you cut the front edge of the tank ? I tried the fork with the Laverda triple clamps once and they touched the tank.
Make notes I want to know everything :)
Why did you modify the Paso axle, didn`t you have the original Laverda one ?
Gerhard
PostPosted: Sun Jan 27, 2008 12:20 am
Yes i do have the laverda axle, but it has three thicknesses.
And the forks I've bought were cheap because the threat was broken.
The threat on the paso axle is 16 x 1,5 mm so i could immediately cut new threat in those forks. (laverda threat is about 14-15 mm.)
Now the forks are just on the bike (had to cut off a piece of iron from the frame to make it fit)
I didn't mount the tank yet, thats a problem for later times.
When i'm finished with the total project i will write a total story of it, with photo's
For now, i've put just a few pics on the net but i will do more.
http://www.mijnalbum.nl/Album=74DRR8H4
I'm just very busy at this time because i just started working for myself, so i hope my pasoproject will be finished in april (it already took me a whole year now :banghead: )
PostPosted: Sun Jan 27, 2008 9:54 am
PostPosted: Sun Jan 27, 2008 11:28 am
Yes i thought about the clipons.
They are from a 916 (risers)
that part is ok, the only problem now is the tank.
But when the tank does not fit, i will make a new one from carbonfiber and epoxi resin bought in your country.
What i'm doing is seriously "over the top" :evil: ,
but there's no way back and i like to do the work.
About the other option; it is easier to fit a early adjustable 900ss fork.
I chose to do it the hard way and will never do it again (you can buy a second hand 750 paso for it).
youll hear from me, ab.
ps. i just added 2 pics in my album.
PostPosted: Sun Jan 27, 2008 11:40 am
Very interesting, zap, keep us posted! :thumbup:
Lovely fenders front and rear, your own fabrication?
PostPosted: Sun Jan 27, 2008 11:57 am
The front fender is a laverda formula, and the rear is a monster.
I just put the tank on my bike to see how big the problems are, and they will not fit yet.
I have to cut a little but not so much.
From now on i will update my photoalbum and try to give some usefull comments each .....two weeks.
Users browsing this forum: Google [Bot] and 83 guests
