ducatipaso.org • View topic - mounting new 907 swingarm
It is currently Sat Mar 07, 2026 11:59 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: mounting new 907 swingarm
PostPosted: Mon Jan 28, 2008 9:08 pm
year: 1985
Hi guys my time is come i miss only rear disc and then i'll have all the "necessaire"to mount my new swingarm with my new tyre(very-soft) :thumbup: :thumbup: :thumbup: :thumbup: :mrgreen: :mrgreen:
Now my question is :
it will be so difficult to disassembe old swingarm and mount the new one?
i need special tools?
all suggestions will be appreciated
lamps
Piero
 Post subject: Re: mounting new 907 swingarm
PostPosted: Tue Jan 29, 2008 10:05 am
Hi Piero,
removing the swingarm and putting the new one in doesn`t require special tools, just the usual and maybe a rubber hammer and a torque wrench.
Just figure out how to make the bike stand stable when you remove wheel and swingarm.
If you don`t know age and condition of the swingarm bearings you should change them, now that the swingarm is not yet in the bike.
PostPosted: Tue Jan 29, 2008 2:33 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Jan 29, 2008 5:26 pm
year: 1985
Thanks guys...but i forget ot ask you one thing do yu now the measure of the spacers to put between swingarm and rear wheel ??
how i have to take this measurements....
P:S:
today i finished to mount 4 piston brembo calipers and semi radialpump from 999.......
what a a difference :wacko: :wacko: :wacko:
:evil: :evil: :evil: :evil:
PostPosted: Tue Jan 29, 2008 7:47 pm
according to the 17" conversion info (that can be found in the downloads thread) it`s 5mm thick, inner diameter 20mm, outer 35mm.
PostPosted: Wed Jan 30, 2008 6:02 pm
year: 1985
:shock: :shock: :shock: :shock:
stange only 5mm of thickness,it seems to me strange the brake caliper support on the other side of the rim is 17,9 mm of thickness :wacko: :wacko: :wacko: :wacko:
i have to investigate
i 'll give you notice
lamps
Piero
PostPosted: Wed Jan 30, 2008 6:13 pm
have you checked the files again ?
But I noticed there`s a difference. You say your brake adapter is 17,9mm, the one of the guy describing the 17" conversion is 10mm. In that case your spacer should be even thinner :!: :?:
PostPosted: Wed Jan 30, 2008 6:25 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Jan 31, 2008 11:51 am
year: 1985
MMMMMMMMMM i have done a wrong in measurement the caliper bracket is 29,8 mm :shock: :shock:
i take this bracket from a monster 900 and it's the type with caliper positionated down....
I think it 's benn a erious problem to take right measurement for sapcers,i'm terrified to think what can be happen if i wrong :dunno: :dunno: :dunno: :dunno: ...
PostPosted: Thu Jan 31, 2008 12:03 pm
Piero, try to ask Zap. He has Supersport wheels on his bike, maybe he can tell you what brake adapter he used and what spacer.
PostPosted: Thu Jan 31, 2008 2:05 pm
year: 1985
Thanks G. but i mount a 907 swingarm,that is larger than stock 750,and as i see by this photo he mount the wheel with the old swingarm......
tel me if i'm in wrong
lamps
Piero
PostPosted: Thu Jan 31, 2008 2:10 pm
sorry I didn`t think of that :banghead: , then of course also the before mentioned spacer is probably incorrect as the 17" wheel conversion (file) was done with the original swingarm also.
PostPosted: Thu Jan 31, 2008 5:32 pm
I don't have my 907 swingarm back from being welded because of some sprocket bolts that backed out, but I do have a 907 caliper bracket and a wheel with sprocket carrier from a '94 SS900 (4.5" width) if there are any measurments that I can help you with.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Jan 31, 2008 7:14 pm
I have a complete 907ie swingarm right at hand and could measure here.
PostPosted: Fri Feb 01, 2008 11:05 am
year: 1985
Thanks guys i'm waiting for your "SAINT"
measurement :beer: :beer: :beer: :beer:
