ducatipaso.org • View topic - mounting new 907 swingarm
It is currently Thu Oct 02, 2025 4:18 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: mounting new 907 swingarm
PostPosted: Sat Feb 02, 2008 5:51 pm
swingarm width 24cm. Terry what`s the wheel width with the sprocket carrier on ?
PostPosted: Mon Feb 04, 2008 2:03 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Feb 06, 2008 11:39 am
year: 1985
c'mon guys..... :D :D :D :D :D
check this size and when you came in naples you'll have a great birra and pizza payed!! :beer: :beer: :beer: :beer:
PostPosted: Wed Feb 06, 2008 4:51 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Feb 07, 2008 1:44 pm
:mad:...... :banghead: I forgot to take the measurements, again. I'm sorry. I got involved in putting the front end back on my Harley. I thought about the measurements while putting the bike back together, but I then got side-tracked by our three year-old daughter. I'll get those measurements very soon. :D
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Feb 08, 2008 1:17 pm
Hurray!!! Hurray!!!.....I got the measurements, but....
I left the paper that I wrote them onto sitting on my work bench. :,(
I'll call my wife in an hour or two and get her to read them to me over the phone......I'm such a slack-ass. :banghead:
Edit - Here are the measurements if I did the conversions correctly for the '94 Supersport 900 rear wheel (4.5" width)..
1) Hub width with sprocket carrier installed - 206mm
2) Hub width without carrier - 171mm
3) '92 907 rear caliper bracket width - 35mm (Correction: it is 28mm wide, NOT 35mm....sorry)
I'd probably 1-2 mm difference because of the inch measurements and my conversions.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Feb 08, 2008 2:01 pm
year: 1985
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
demon you 'll be my guest when you'll come in naples :beer:
PostPosted: Fri Feb 08, 2008 2:13 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sat Feb 09, 2008 12:19 pm
year: 1985
mmmmmmm
Today i assemble all my elements of the swingarm and i noticed that there isn't any spaces for any spacers..... :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
i add some pictures
what do you think???? :banghead:
PostPosted: Sat Feb 09, 2008 3:55 pm
From what modell is that Your rear brake caliper holder, cause seem, that caliper will come UNDERside, not upper, like normally ???
I think, that if U dont have any space for spacers, then Your only problem will be chain line and it can be "modified" with different offset rear sprockets.... Ducati make manykind of different offset front sprockets and u can use also spacers in front sprocket to adjust chain line.... I havent read hole topic, so peg me pardon, if i talk something "shit" now... :lol:
PostPosted: Mon Feb 11, 2008 2:41 pm
year: 1985
mmm i hope it is like you say..... :beer: :beer: :beer: :beer: :beer: :beer: :beer:
but i'm not convinced so much....
PostPosted: Mon Feb 11, 2008 3:17 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Feb 11, 2008 3:18 pm
I can take a measurement of the spacer on an ST2 wheel to see how much it projects from the sprocket carrier, if you need. The other measurements of the spacer would not be any good to you, as the axle diameter of the ST2 is 25mm, so the ID of the spacer and OD of the smaller side would be significantly different for a spacer for a 17mm axle. Gerhard, do you have a 907 spacer you can measure?
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Feb 11, 2008 4:04 pm
My ST2 spacer is just out of its place, so:
Thickness is 8,67mm(hahahahaha) from digital gauge.
Inner hole diameter is 30.05mm
Outer diameter from bigger end(to outside/swingarm side) is: 45.00 mm
Outer diameter from smaler end(to inside/wheel side) is: 35,50 mm (about)
looks exact, like in Desmo_Demons drawing :thumbup:
PostPosted: Mon Feb 11, 2008 4:41 pm
