ducatipaso.org • View topic - 750 Paso front brake adapters to swap 320 rotors to M1R
It is currently Tue Feb 10, 2026 6:04 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: 750 Paso front brake adapters to swap 320 rotors to M1R
PostPosted: Mon Feb 04, 2008 1:02 pm
Those adpters look very similar, as i use now with just same calipers, BUT to 280mm rotors. I want calipers to 320mm rotors wit same black brembos... :thumbup:
PostPosted: Mon Feb 04, 2008 1:08 pm
and that is what they are also offering, They have different size adapters as it says: 280 to 280, from 280 to 300, from 300 to 320
You can contact them at: ducati-dortmund@online.de
As it seems the parts on ebay are original MQ, these seem self machined.
(send CC to ducati-dortmund@t-online.de as I think the email adress above, which comes from their site, is incorrect)
PostPosted: Mon Feb 04, 2008 5:19 pm
PostPosted: Tue Feb 05, 2008 6:39 am
intresting.... But is that 65€ for pair, or one ??? Gerhard! If pair, then i contact to them... :thumbup:
PostPosted: Tue Feb 05, 2008 5:04 pm
PostPosted: Wed Feb 06, 2008 6:48 am
Yes! Was that 08, that black original 750/906 caliper? After i have used those 4 pistons(from 907IE)in my 750 Paso, i never go back to those original ones.... NEVER! :thumbup:
PostPosted: Fri Mar 21, 2008 4:44 pm
Hey Antti,
before you left on vacation I had pointed you to some MotoQuality adapters on ebay.
As you weren`t interested (although they were exactly what you were looking for) and they may come handy for me (Marvic rims with bigger brake discs) I bought them.
Here`s the drawing. It cost me todays rainy afternoon and as I have a bad headache now I didn`t doublecheck everything but I think it should be ok. (the .ppt file is better printable)
http://www.box.net/shared/tnyfou50ck
PS: the picture above shows the adapters mounted incorrectly btw. What the adapters mainly do is shifting the caliper backwards to make it fit on discs with a bigger radius.
PostPosted: Fri Mar 21, 2008 4:59 pm
the adapters fit with both 300 and 320mm discs. It just depends which way round you mount them.
Here a pic of my 280mm adapter (left) and the 300/320mm adapters.
As the mounting holes for the caliper are not centered, the caliper will be in a different position depending on if you put the adapter on the left or right side of the fork.
PostPosted: Fri Mar 21, 2008 7:47 pm
Hi !
Currently i have just same adopters, as You(those in left). I use them with normal 750 Paso M1R fork with 907IE black calipers and normal 750 Paso rotors.
Seems, that now i have found, what i was looking for..... :thumbup: :thumbup: :thumbup: :thumbup:
I REALLY apperiate You, Gerhard, how much You have time to do all that work with computer :thumbup: :thumbup: :thumbup: I downloaded already measurements to laptop, so seems, that i give them close times to my friend, "lathe man"... VERY good drawings, so very many thanks to you, Gerhard.... :thumbup: Hopefully we meet one day and then i buy dinner to you.... :thumbup:
Btw, i noticed from You last foto, that there is stamped both 300 and 320 !!!!
PostPosted: Fri Mar 21, 2008 7:56 pm
PostPosted: Fri Mar 21, 2008 10:27 pm
Yes, Frankie! :mrgreen:
PostPosted: Sat Mar 22, 2008 2:08 pm
Antti, there`s not much else to do on a rainy, cold afternoon on a holiday! :truck:
If you get .eps or .dwg drawings let me know. I`ll upload them here.
If I missed some measurement let me know also and I will check. I used the file that Roy made for me for the old adapters and just modified it a bit.
PostPosted: Sat Mar 22, 2008 10:03 pm
Another good idea would be drawing the Motorquality right ones, that are very clever.
Replacing the stock rotors with the 320 ones would get an huge braking improvement.
Ciao :beer: :beer: :beer:
PostPosted: Sun Mar 23, 2008 9:41 am
