ducatipaso.org • View topic - Original 280 rotors on 17 " wheels?
It is currently Wed Mar 11, 2026 1:11 pm
 Post subject: Original 280 rotors on 17 " wheels?
PostPosted: Thu Feb 07, 2008 10:26 am
When converting to 17 “ wheels, has any one used the 280 front rotors with some kind of adapter to fit the wheels? It looks as if on this F1 there is fitted an adapter. :
And if so, where do i get such a pair?
Regards Klaus
 Post subject: Re: Original 280 rotors on 17 " wheels?
PostPosted: Thu Feb 07, 2008 11:20 am
it`s a 750 Sport. However I doubt that there are many 17" conversions keeping the small brake discs.
As it seems the adapters are part of the PVM wheels, here`s a pic I found on another german page:
PostPosted: Thu Feb 07, 2008 2:00 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Feb 07, 2008 3:51 pm
You are properly right. It was only because that there are no discs with the wheels that I have just purchased and the discs on my 16” are quit new.
Regards Klaus
PostPosted: Thu Feb 07, 2008 6:53 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Feb 08, 2008 10:06 pm
Desmo Demon; I think JUST as You !!!! Why to use so awfull 2 piston calipers? :banghead: :banghead: :banghead:
PostPosted: Sat Feb 09, 2008 7:28 am
I changed the whole front brake system (Brembo full floating rotors, newer goldline calipers, 999's radial master cylinder and braided lines).
I'm very, very happy.
PostPosted: Sat Feb 09, 2008 8:50 am
I changed hole 907 system(with steel braided lines) to my 750 Paso, but still original iron rotors.. I am also very happy to it now.... I want to keep that combination also, when i swap 17" wheels and then add 320 rotors(from 92 907). :smoke:
PostPosted: Mon Feb 11, 2008 3:51 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
