ducatipaso.org • View topic - new member with beat up 87
It is currently Sun Jun 21, 2026 7:03 pm
 Post subject: new member with beat up 87
PostPosted: Fri Jan 25, 2008 10:41 pm
hi jus researching madly about my poor old bike its been through the wars 1st swing arm bolt holes butchered [getting welded an machined] 2 about 15 teeth missing off 3rd gear/3 housing broken were chain mustve snapped /4 cluth pack down to steel on some/5 fairings need repair an repaint/so while im at it will do cam belts/sprokets an chain if finances allow so once i figure out how to post my pics i will put down a more detailed history look forwardto any help and friends i might meet on the way
 Post subject: Re: new member with beat up 87
PostPosted: Sat Jan 26, 2008 1:11 am
We will help you.
Welcome!
PostPosted: Mon Feb 25, 2008 10:02 pm
Devo87,
I am also in Christchurch, bought a wreck 5 years ago, have changed to Mukuni carbs,hone and rings,clutch,rectifier probs,rebuild heads,clutch slave sleeve/rebuild, 2 repaints etc etc etc and in the process of changing to 17" rear.
I could probably give you some good info.......how to....where to go, etc :phone:
Tony
e-mail
tony.devries@telecom.co.nz
PostPosted: Mon Feb 25, 2008 10:11 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Feb 26, 2008 7:15 am
You'll have to work!!!
Good luck!
PostPosted: Tue Feb 26, 2008 9:16 am
welcome, I guess one of the first things you`ll want is:
http://www.desmotimes.com/product70.htm
I have one of those. It`s currently being powder coated. I`ll make a drawing when I get it back as I figure it`s not hard to make one yourself.
Good luck with your rebuild. Upcoming frustration will be gone the first time you hear the bike and when you ride it :thumbup:
PS: to post pics upload them on ie photobucket.com (you need to register but it`s for free), then when posting in the forum copy the direct link of the picture into your post after you clicked on "Img" which you`l find above your editing window. So then it is [img]direct-link-to-jpg[/img]
PostPosted: Wed Feb 27, 2008 6:26 am
Devo87,
When did you buy the Paso; it's just I remember seeing a white one advertised on TradeMe last year, that was from Christchurch, that looked like it needed a bit of help?
Lots of assistance from this site, hope we can help.
Fraser.
PostPosted: Wed Mar 05, 2008 1:12 pm
Ouch, the broken engine case is really a bad deal. It could require a complete tear down to make a repair or replace. I had the output bearing fail and chew up the case. I bought a new bottom end instead of tearing it down.
We're here to help!
