It is currently Sun Jun 21, 2026 8:11 am
| Author |
Johnnie
Post subject: New Ducati owner 88 limited Posted: Wed Feb 27, 2008 4:04 am |
I recently bought the 88 limited that was for sale on ebay in Glendale AZ, I did as much research as I could and feel confident its a real one. I wanted a red one but couldnt pass up the limited for obvious reasons.I'm going thru it now most of the items that need attention are relativley easy fixes (brake light switches, front tire, breather tube and breather filter, turn signal lens. Unfortunatley the previous owner replaced the large original mufflers with standard paso units, I guess the original ones were kinda rough and he ended up throwing them away. does anyone know if the big muffs show up for sale occasionally??? the only other non stock item is the 906 mikunis that were installed which I would have done anyway. this is my first duc, I always lusted after the pasos and I cant believe I didnt take the opportunity to ride one back in the 80s, I wasted all these years riding my kawasakis when I could have had one of these. It's never to late to change!!! John
| Top |
Post subject: Re: New Ducati owner 88 limited Posted: Wed Feb 27, 2008 9:40 am |
| paso grand pooh-bah |
John, welcome. Like every new Paso owner you should check the service history of the bike. In case you don`t have that info check valve clearance and replace the belts also. The Mikunis come from a Supersport or Monster as the 906 had the same Weber carb as the P750. The race cans that came with the Limiteds are for race use only. I`d say also on ebay they are hard to find.
| Top |
Desmo_Demon
Post subject: Re: New Ducati owner 88 limited Posted: Wed Feb 27, 2008 1:35 pm |
Joined: Fri Jul 21, 2006 12:00 am Posts: 869 Location: Easley, SC
_________________ 2002 Ducati 748 monoposto 1998 Ducati ST2 1996 Suzuki GSXR-1100 1994 Bimota DB2 1988 MegaPaso 916 project 1987 Ducati Paso 750 1985 Harley FXEF 2001 Ducati M900ie (wife's) 2000 Yamaha YZF-R1 (wife's) 1998 Ducati ST2 (wife's) 1994 Suzuki GSX-750R (wife's)
| Top |
Debonair
Post subject: Re: New Ducati owner 88 limited Posted: Sun Mar 02, 2008 7:06 am |
What's up guys? I just bought my first Ducati today! It's an 88 750 paso and it came with F1s pipes. It does not run at this time. I think it's got oil in the starter, theres power going to it but it doesn't turn. I will get it going soon....
| Top |
Post subject: Re: New Ducati owner 88 limited Posted: Sun Mar 02, 2008 10:51 am |
check the brushes of your starter, they might be worn.
| Top |
Debonair
Post subject: Re: New Ducati owner 88 limited Posted: Mon Mar 03, 2008 4:44 am |
I'm looking to re-do it all brushes, commutator and seals if I can find them! I'm really excited because I have never riden a Ducati, I have a 92 GSX-1100g and an 82 Yamaha Vision so I really want to hurry up and get the Paso going. I will keep all of you posted on my improvement.....
| Top |
persempre907
Post subject: Re: New Ducati owner 88 limited Posted: Mon Mar 03, 2008 4:39 pm |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
Drive carefully your Paso the first times, and above all, take care in the corners... Never brake in it! Ciao
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
Debonair
Post subject: Re: New Ducati owner 88 limited Posted: Tue Mar 04, 2008 2:27 am |
Thanks, I'll try to remember that! Can you tell me what kind of engine oil you recommend and how much to use.
| Top |
jcslocum
Post subject: Re: New Ducati owner 88 limited Posted: Wed Mar 05, 2008 1:22 pm |
I've never seen oil in the starter. Do you see oil coming from it??
Gerhard is right, check the brushes. This can be done with the starter mounted to the engine and is relatively easy to do. There are also electric/wiring issues with the Paso that seriuosly effect starting so please read thru the FAQ at the top of the forum. We have tried to compile every problem you might encounter!
Replace the belts before riding if you don't know their age and just use a good 10-40W or 20-50W motorcycle oil. My Paso liked regular motor oil vs. synthetic.
| Top |
Desmo_Demon
Post subject: Re: New Ducati owner 88 limited Posted: Wed Mar 05, 2008 1:40 pm |
| Top |
Debonair
Post subject: Re: New Ducati owner 88 limited Posted: Thu Mar 06, 2008 12:30 am |
Can you guys tell me where I can acquire the belts,starter brushes etc. here in the states. I'm sure to find a place but since you are veterans here ,maybe you can guide me...
| Top |
Post subject: Re: New Ducati owner 88 limited Posted: Thu Mar 06, 2008 9:21 am |
some parts, like belts or turn signal covers you should be able to order and get via your Duc dealer. Have you tried the search function of the forum for the starter brushes ? This was discussed a few times already.
| Top |
jcslocum
Post subject: Re: New Ducati owner 88 limited Posted: Thu Mar 06, 2008 5:03 pm |
This is the only place to call in the USA: Miles English Parts Manager BCM Motorsports 603-524-4898 http://www.bcmducati.comMiles will take care of you. Make sure to tell him Jon Slocum sent you.
| Top |
Debonair
Post subject: Re: New Ducati owner 88 limited Posted: Fri Mar 07, 2008 2:26 am |
Will do Jon, thanks for the info!
| Top |
Finnpaso
Post subject: Re: New Ducati owner 88 limited Posted: Fri Mar 07, 2008 7:02 pm |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
Users browsing this forum: No registered users and 27 guests |
